Monica (my '93 TXD TD hatch) has developed an annoying habit!
All four doors unlock on the plip without problem, but when locking again, the drivers door just doesn't want to lock, so I have to use the key on it.
I'm assuming it will be a problem with the solenoid on the drivers door (or the associated wiring in the door).
Funny thing is, the 'master' solenoid seems to be fitted to the passenger door, as this is the door button that locks all four doors from inside. The drivers side door button will only lock the drivers door.
I plan to take off the door card and have a gander inside at weekend. Is there anything else that I should be checking while in there?
Thanks in advance.
Dave
