Woke up to find a lot of lhm under the car, not the usual drip from the fdv but a significant amount from the driver side . Upon inspection i found the driver side strut return line split. Started the car and waited for the car to go up to make sure it was a low pressure leak .
Then put the car on stands to get the wheels off, but the wheels werent retracting up to the arches like it should . It went up to all the selector positions as it should except when on the lowest setting the wheels didn't get off the ground while on stands. Can someone please explain?
Massive lhm leak under the car.
DFF53
Grenouille Rouge
DFF53
Hi Kiwi, So it is due to lack of pressure as i thought, i fear that this problem might have been caused by myself not jacking the car up properly. The other day i jacked up the car just on one side of the car to patch the passenger side return line leaving the driver side wheel firmly on the ground, possibly putting too much pressure on it . This leak only happened the day after that.
did you get a replacement return line or did you have it patched up. If so, who stocks the replacement line and how much is it?
Grenouille Rouge
Funny you mentioned it, I never gave it any though when jacking the car of what you think happened but now I think of it there has been the odd occasion this has happened.
Regarding the return lines I had a a new spare lying around (back up) and found a good one I had floating around from a BX that was dismantled, it was a newish one when I took it off (no cracking).
The botch and pray repairs finally got to the point of having to do...the TZS got through its WOF then the repair gave out the following day
Figured might as well do the TRS at the same time being due next month.
May even replace the CV boot as well if it passes without any major points (not that NZ WOFs are that good).
Re: Massive lhm leak under the car.
I don't believe the BX is designed to do this although it is applicable to some other Citroen models.DFF53 wrote:
Coincidence, the return lines are unpressurised. It is however possible that extending the car upwards in order to jack caused the already perished return pipes to crack and therefore leak.DFF53 wrote:The other day i jacked up the car just on one side of the car to patch the passenger side return line leaving the driver side wheel firmly on the ground, possibly putting too much pressure on it . This leak only happened the day after that.
