I've finally disinterred my 1990 4*4, after around 7 years in store(I know!).
I've enjoyed driving the ordinary Gti so much that I decided to resolve the 'issues'' with t'other.
Its now running fine, no leaks yet.
However, front is scraping the ground, arse is way up in the air, which happened the minute I shifted the (very stiff) height adjuster to high - just wont alter.
Leave it 2 days -backside comes down, but goes straight back up the minute it starts.
Is it the height adjuster thingy-between the seats- and if so how do I get at it? What needs hitting with a club hammer?
Would jacking the front high (too take the weight off) help -or levering the wishbones down-before I fire it up?
I'm reasonably mechanically orientated -but not BX savvy.
Pre-exisiting issues revolve around clutch & exhaust -typical on these....
Front won't come up,back won't go down!
Nigel Bickle
BX Gti,
HY van
HY van
Oscar
Get it up on ramps/axle stands and make sure it can't fall on your head. Then get under it and smear grease all over the height correctors (small drums covered with a rubber diaphragm fore and aft - the front one is at the back of the engine, the rear one by the rear axle), and grease all the height lever linkages while you're under there.
Then get it off ramps and give it 15 minutes of Citrobics - engine running, down to minimum height, back up to maximum, repeat.
If that fails, ask someone more qualified than me!
Good luck!
Good luck!
Adrian E
If it won't respond to any command from the lever inside the car, it may be you've managed to break something in the linkage under the car - if you undo both height correctors completely where they attach to the antiroll bars, one end will reach for the skies, the other hit the floor - can't remember if it's the way round you've got, but sounds very much like a possibility.
If the linkage was siezed and you managed to free it off, it may be you've managed to push the height corrector adjustment round on the roll bar? In which case resetting the height correctors (following the extremely important advice NOT to get under the car unsupported!) may sort your issue.
Do note that setting the ride height correctly does need the car supported on its wheels, ideally on a proper vehicle lift. A tiny tweak of the height correctors can have the car bouncing up and down on your head!
the reason the lever becomes very stiff to move is usualydown to the rear link pivot, which hangs from the rear axle beam and the rod from the in car lever hooks into, just follow to the rear the rod which runs both directions to front and rear from the hight lever,
free that link of at its pivot point as it runs up and down a thread,
then you will need to free off the mechanisum at/around the front hight corrector, which you will find at the front end of the a rod,
the H/C's very seldom give any trouble at all and its usualy down to the linkages being seized
JayW
- x 13
Nigel Bickle
