smelly car
Phil Brook
smelly car
When I open the roof window when going slowly or decelerating an engine/exhaust smell is evident. I have had the exhaust checked and told this is ok-any ideas how I could cure this? - without just shutting the window!!
Philbrook
Oscar
scarecrow
Gibbo2286
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
...or spam penis. Which sounds like an ailment... :S
Ray
www.citroencarclub.co.uk
Linegeist
Just to get back on subject .........................
...................... I think you'll find this is a product of the aerodynamics of the 'Kamm chop' BX bodyshell.
My Athena had an aftermarket exhaust fitted when I bought it, and the tailpipe varied significantly from the OE pattern. Every time I opened the sunroof, the car started to stink of exhaust fumes ............
After much futzing, about-buggering and auto-phrenology (none of which worked) I circumcised the tailpipe, and reattached it using the MIG welder with a 2" extension (oooer nurse!!
) and a 20 degree twist that pointed the outlet straight down rather than half left .....
Result? The exhaust gases now emerge into a turbulent area where the airflow whips them away from the car rather than up and over - so no more fumes.
rayfenwick
By jove - I think he's got it!
I wonder if the problem is affected noticeably by which spoiler is fitted (if any)...
Ray
