As always, all help gratefully received.
Rear Fogs not working
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
Hi all. Just noticed the rear fogs aren't working. It's not the bulbs, and the contacts in the holders look ok, so where to check next. As it is both sides I'm guessing there's a relay somewhere - unless Citroen decided to save £1 and wire directly to the switch?
Ray
www.citroencarclub.co.uk
rayfenwick
I swapped the switch, same result, though the other switch is untested.
Fuse... I've not found (or in fairness looked for....) the fusebox yet. :S
I'm guessing that's a "no" to the relay then?
Ray
electrokid
rayfenwick
Well.. in fairness I did mention that in my first posting, not that I hadn't thought of it.Defender110 wrote:Come on Ray,. . . . .an electronics guru hasn't checked the fuse![]()
I thought I'd ask from those who've trod the path before me - prior knowledge can often save a lot of faffing about with a multimeter....
I'll check fuses and do some waggling as suggested and get back to you all. At least there's no relay involved
Ray
electrokid
Different countries have different regulations for fog lamp use and wiring. In the Uk it's only legal to use front foglights during 'fog or falling snow' and (certainly in the past - not sure about now) there are regulations governing the wiring to prevent them being used on their own.Wrong!!!
If you are talking about the ph2 BX. Either that or I got two BXs here with a fault that allows them to work
It should be from the sidelight circuit - the original idea - and use - of foglights was to reduce 'backscatter'. Normal headlights will illuminate the fog immediately in front of the vehicle - and it's more difficult to see through illuminated fog.
The idea of having a flat beam prevents this illuminated fog getting in the way of seeing clearly in these conditions so the ideal in a pea-souper is to use front fogs only when appropriate.
The regulations for the wiring of the front fogs became applied to the rear fogs as well.
2002 C5 HDi SX estate
Rather coincidentally I was changing a rear foglight bulb yesterday, and yes, I can confirm (on my BX) the rear foglights are only illuminated when dipped beam is on. (Would you like me to post up a video of this?
We can only speak from our own experiences, all I think electrokid was trying to do was point out that your observations may not be applicable to those in the UK if there are wiring differences on cars for different countries.
Only illuminated through the headlamp circuit i.e. both dipped and main beam but not side lights!
Brian
Linegeist
