TD on e-bay
Stinkwheel
TD on e-bay
Post by Stinkwheel »
E-bay item number - 4601380762
Rear end damage but good donor for all those dodgy 1600 petrols around the place.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
Problem is that he wants at least £50 for it, (as thats the minimum you can have a reserve for) and it's not worth that. I've yet to pay any money for a BX, and one of them even came with MOT!
Stinkwheel
good point David.
never mnd then, actually i had failed to realise he even had a reserve. DOH!!
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Keeper of the site Goat
Post by cavmad »
It`ll be more than £50 as although no bids it`s showing £50 reserve not me. This car has been mentioned on here fairly recently butv I`m sure there were more pictures of it last time round.
I`d have thought it was still worth £70 perhaps to someone who wanted the engine and box out of it?
Vauxhall apologist.
Are you sure about that.... I think it's showing £5 (reserve not met)
True, the engine and box will probably be worth more than £50, but only once removed from the car. The fact that the engine and box come with an attached BX devalues them somewhat, as you have to spend 2 hours getting the engine out, and then do something with what remains.
mnde
Meteor Man
Post by mnde »
But said BX does have MOT and allegedly runs fine. So it's a self-transporting engine and box, and you can try the engine out before you swap it ;)
Mark.
Here's a question then...
Since it is clearly damaged and wouldn't pass another MOT (all doors, including tailgate must open for the MOT, and the rear structure is clearly damaged) is it legal to drive on the road? I would have said not, as it's now unroadworthy.
I also wonder if any insurer would cover it, as it's clearly "structurally modified"
Hmmmmmmm.
tim leech
Post by tim leech »
True you would get pulled be the plod driving that about! Unless its a nissan sunny and you live in burton and then you can do what you like! lol
Stinkwheel
I had a CX22TRS that was hit up the bum as i sat at traffic lights by an uninsured driver that could not speak english, helpful.
Anywho, it was bent bad, the rear chassis longerons were cracked, the bootlid had to have a crowbar and lump hammer taken to it to open it up. BVut all doors worked and after more beating with hammer the boot would open and close too. Looked nasty though. I drove it for another month like this, coppers didnt bat an eyelid.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Stewart (oily!)
Post by Stewart (oily!) »
That car would probably respond to a little "Body English" to the boot floor with the number 3 Hammer, and a little clearancing in the rear doorframe, as long as the rear wheels are pointing in the right direction :D
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
