Identifying correct octopus
JohnW
Post by JohnW »
More on octopuses!
I've located octopuses, but for a slightly more recent ORG number (essentially early 1991 instead of early 1990).
The parts number is different but I have no knowledge of how much and/or in what way my January 1990 BX 19TZi octopus might have been changed by early 1991.
I wondered whether anyone would know in UK, as there are far more BXs there than here.
Cheers and thanks
if you give me the last 8 digits of your chassis/VIN No. i will get you the corect OE part No. for your car,
but im 99% sure the one your looking at will be fine, as from faidding memorry the main diference is power or steering or not
JohnW
Post by JohnW »
citronut wrote:if you give me the last 8 digits of your chassis/VIN No. i will get you the corect OE part No. for your car,
Thanks Malcolm,
Our VIN number is VF7XBEZ0000E28004 and the car has power steering. They were well optioned for Australia (and so expensive that only 6 Estates were sold in Western Australia as far as I know. Ours is a Jan 1990 build 19 TZi.
Malcolm, you are correct there are 2 different versions of the big octopus, pas & non pas versions. Not sure if there is just the single version of the small octopus or not?
both early and later cars with power steering are the same as below for the main octapussy,
96030258 OIL BACK HARNES 46.72 GBP 54.90 GBP 54.90 GBP
below is a return i would call the main power steering return, this one has two types/part No.'s, the first one for diesel cars and the second for petrol cars,
95603420 OIL BACK HARNES 74.39 GBP 87.41 GBP 87.41 GBP
95603421 OIL BACK HARNES 76.14 GBP 89.46 GBP 89.46 GBP
JohnW
Post by JohnW »
citronut wrote:both early and later cars with power steering are the same as below for the main octapussy,
Many thanks Malcolm. Your help much appreciated!
Kind regards
John Waterhouse
