You know, you set out to do something that you've been dreading and you just sail through it without stress or complication. That's my day today.
Decided I should start the MOT prep on the oil burner and figured i may as well get the worst job out of the way first: Radius Arm Bearings...
As it went, no seized nuts, no snapped bolts, no hassles, no scuffed knuckles, no problems whatsoever! Had both arms off in less than an hour including a cuppa...
Of the four or five sets i've had to take off this is the first time i've actually enjoyed it, even though it was ZERO degrees outside!
