1.9 BX TGD AUTO Diesel /Scrapped.
Gazza 1991
SCRAPPED -Happy BXing too all.
Sorry to here your tail Gazza but realisticly I doubt very much you will get £300 for your car with the head gasket gone, The cars are only fetching that sort of money as good runners.
Good luck anyway.
Good luck anyway.
Gazza 1991
Many thanks Kevan .Defender110 wrote:Sorry to here your tail Gazza but realisticly I doubt very much you will get £300 for your car with the head gasket gone, The cars are only fetching that sort of money as good runners.
Good luck anyway.
I know you are being realistic ,But its worth a try, i will be sorry to see the old girl go, and i wish she was in mutch beter health.
Kindest ,Gary.
Not wishing to hijack this thread, but why do these diesel auto's suffer so much with HG failure? I've lost count of the number I've come across, same with 2.1XM's
I've a BX 19tgd auto here parked on the drive with HG failure that I bought a couple of weeks ago, it drove home from London with no problems and has pressure in the cooling system. I paid £100 for it with 10 months MOT, 2 new tyres, new rad, new battery and new spheres. I couldn't bear the thought of all those new parts going to waste. The bodywork has seen better days although there is no rust visible, just a few dings here and there.
Sadly I think you'll be very lucky to find a home for this one, but you never know.
Good luck.
Good luck.
Gazza 1991
Hi Ken.ken newbold wrote:Not wishing to hijack this thread, but why do these diesel auto's suffer so much with HG failure? I've lost count of the number I've come across, same with 2.1XM's![]()
Good luck.
A lot of time reading about the XUD9 over the last 12 months has lead me to belive that you either get a good one or a bad one.These motors are very paticular about coolant level and bleeding of the sytem.Having replaced the HG once to a higher standard than any garage could do it for me and a lot cheaper i think the only way to go with one of these motors if the rest of the car is worth it and the bottom end is in good order is to put a shiney new head on and hope for the best.
I am getting on these day's and decided that i was beaten which is not like me at all,But the wife is not in the best of health neither am i ,so i have made the decision to get a modern petrol and and have done with them HG problems of the XUD ,i hope.
I will be sorry to se the old BX go having got to know them inside out, but in to the modern world i must go ,a bit sooner than expected.
All the best Ken with BX, Kindest ,Gary.
richardd1652
Dads original 19Na in his auto was a sterling motor, and still lives on with original HG to this day, just not in his car.ken newbold wrote:Not wishing to hijack this thread, but why do these diesel auto's suffer so much with HG failure? I've lost count of the number I've come across, same with 2.1XM's![]()
MY old 21TD XM auto had HG failure though, and I do wonder if it has more to do witht he autobox, since the heat exchanger on it runs the engines coolant, therefore maybe putting a bit too much strain on an already fairly marginal cooling system?
- BX Digit man!
Coupled with the fact that an engine with an auto box works harder (uses more fuel, hence more waste heat to disperse) and you're looking at an engine that not only gets hotter than it's manual equivalent, but also has a wider heat range in service (difference between light-load temperature and full-load temperature) meaning more differential expansion, and more stress on the HG.docchevron wrote:I do wonder if it has more to do with the autobox, since the heat exchanger on it runs the engines coolant, therefore maybe putting a bit too much strain on an already fairly marginal cooling system?
It's a theory......
electrokid
It's a good oneIt's a theory......
I've been looking at rad fan switches recently to convert the TGD to dual fan - there are a variety of temp switching points available so I've chosen the lowest temp ranges that seem to be available - I've just bought a couple of these...
http://cgi.ebay.co.uk/RADIATOR-FAN-SWIT ... 0627756561
There's a whole bunch of different part Nos. listed on eBay for the BX but the temp ranges are different so worth checking when you buy. Probably worth fitting the lowest temp range version to the auto - HG failures in autos might be down to the wrong temp switch fitted or the perennial problems with the fan electrics. Or, of course, using tapwater instead of de-ionised water in the rad.
(Edited to shrink the link - MF).
Thanks Mat.
2002 C5 HDi SX estate
sdelasal
/\ true, but by the time you're in top gear then you're usually just cruising, most hard acceleration is done through the gears, and even at higher speeds if you really toe it the box will still change down, unless you're doing illegal speeds.
richardd1652 wrote:Pm,d.
Richard.
richardd1652
