frozen door tip
frozen door tip
I've strugggled getting my doors open in the morning during this cold snap as I know others have, I've been told a smearing of vaseline on the door seals will stop the doors freezing shut.
kermit the frog
Post by kermit the frog »
Thanks i'll try that doors were frozen shut yesterday morning on the Green Hornet and i wanted to move it but could not get into it.
Post by Mothman »
Also, if you cant get the key to work, you can always pee on the door lock, this usually makes it work. :lol:
I ain't getting mine out in -10 for nobody! :shock:
grecian
Post by grecian »
I find a kettle of warm water works well - and you won't get arrested
previous- GS, Visa, 19DTR, 4x4, now ZX 1.9D and 1985 BMW M5
I find that in these temperatures I get the 'peeing through a pepperpot' syndrome, so I'd get one stream down the door, one down the wing, one down the passer by and the rest down my trouser leg…that's if I can find it at all!
Post by Mothman »
mat_fenwick wrote:I find that in these temperatures I get the 'peeing through a pepperpot' syndrome, so I'd get one stream down the door, one down the wing, one down the passer by and the rest down my trouser leg…that's if I can find it at all!
I get like that after about 18 pints, mind you, i usually cant see where nor care where its going by then :oops:.
:lol: Enough of peeing on your car just get some silicone spray on your door seals works a treat. :wink:
mds141 wrote::lol: Enough of peeing on your car just get some silicone spray on your door seals works a treat. :wink:
So long as you don't need any paint work doing at a later date :(
nige
Post by nige »
make sure the door is unlocked before you try force it open - happened to me, Mrs left the car unlocked, i went to unlock it in the morning and inadvertantly locked it :roll:
all i want for christmas is a dukla prague away kit
The fleet:
1992 Citroen BX 19TXD
1972 VW Camper
1969 Triumph Spitfire MKIII
1984 Kawasaki Z750
2002 Ibiza Seat
:lol: I know all about that one :oops:
