Fuel pipe leaking from tank area, usual pipe I expect
Smallish hole in boot floor where exhaust hanger has come off.
Exhaust rear box insecure (see above)
Washers in/op (blockage in wiper motor somewhere as the pump works fine)
ABS lamp on, could just be a bad connection
NSF Strut Return Split, easy job
Advisory on a brake flexi (not a fail)
Failed emissions as idle was too high but now seems OK
So what to do???
Option 1
Wait until the warmer weather and get it done if I can afford it, it does drive lovely and has cleaned up well, but the bonnet and roof arent good. Asides the boot floor its solid and the interiors MINT. All spheres have been re-gassed and everything works.
Option 2
Take some bits off, scrap it and get my money back
Option 3
Someone on here takes it on who is more mechanically adept than myself, anyone???
