CV boot question
CV boot question
When fitted new or if you buy a genuine CV boot kit there is a white plastic piece that fits inside the small end of the boot. What is it supposed to do? It doesn't fit all the way round the shaft and suely the boot would seal better onto the shaft if in direct contact? befuzzled! :?
Linegeist
Post by Linegeist »
A village is missing its idiot for sure! :roll: :lol:
There was me thinking you'd come through with my answer :( :)
It allows the boot to slightly rotate about this point with suspension movement, which wouldn't happen if the boot was clamped directly to the shaft. This in turn prevents the boot puckering up and possibly getting chewed by the CV joint itself. :)
Linegeist
Post by Linegeist »
Defender110 wrote:There was me thinking you'd come through with my answer :( :)
Sorry Kev - somehow this reply should have gone onto the bomb thread - but ended up here! :shock: :shock: :shock:
Shall I have myself thrashed with wet luttuce now - or later? :D
Way2go wrote:It allows the boot to slightly rotate about this point with suspension movement, which wouldn't happen if the boot was clamped directly to the shaft. This in turn prevents the boot puckering up and possibly getting chewed by the CV joint itself. :)
Thank you, Now I know that I will now go and insert it! :oops:
