Tried to send a PM today,, but all attempts wound up in my outbox, despite the report that they had been sent,, and the outbox doesn't give you the option to send.. (icon was screwy too)
I probably ended up sending the same message 4 times!!
Any one else experiencing similar issues with PM system..
problems with private messaging
B-Hive
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
scarecrow
rayfenwick
Yes, that seems to be the way it works.
Ray
www.citroencarclub.co.uk
rayfenwick wrote:Yes, that seems to be the way it works.
"2BXORNOT2BX",
Just try sending a 'Test PM' to your-self, you will see it in your 'PM out-box' (Then if you want go to your personal E-Mail to see a message delivery from the BX webmaster) or just go to your 'PM In-box' after sending the 'Test PM' when you open the PM the message then also shift's to your 'PM Sent-box' (you should then see the same 'Test PM' sitting there too).
If that flow/sequence doe's not happen then you may have a problem (But I very much doubt it) !
I hope that is of help to you.
B-Hive
