WANTED - tzd / A8A plastic lower timing cover
themildbunch
Post by themildbunch »
Managed to snap mine today when replacing the waterpump!
Turned out though that it was already cracked and very weakened at the bottom by some previous cack handed mechanic (not me this time!)
I've had to refit the broken one for now but I'd rather have the proper piece and I don't want too much crud getting up onto the belt..
adrian
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
The bit thats held on with a pair of 11mm bolts, oes round the crank pulley?
Should be able to sort you one of those no problem, but I doubt I'll be near one for a couple of weeks if that suits?
themildbunch
yep, that's the one - no problem on the time - let me know when you have it and I can probably collect as I'm in the Stroud / Minchinhampton area quite alot..
cheers
adrian
1988 BX 19 Gti 16v
No worries, I'll send a PM when I have one in my sweaty palm, I'm also in the Bristol area quite alot!
