how do i remove the front indicator lamps please?
johnbird
Post by johnbird »
there is a little green algae in the corners of the indicator lights.easiest way to remove it i guess is take the unit out and dishwasher it.had a quick look but its not obvious how these remove.after cutting my fingers to ribbons changing the heater illumination bulbs i thought it best to ask.
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
easy
yank the head lamp out the ther is a 10mm nut which you loosen then slide the indicator unit out
johnbird
Post by johnbird »
could you define yank the headlamp out please?
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
rmattila
Post by rmattila »
johnbird wrote:could you define yank the headlamp out please?
Ball & socket mountings (see figure), can be carefully prised out.
johnbird
Post by johnbird »
wow a picture-worth a thousand words- that looks simple enough.will give it a try,thanks for clarifying that for me.job for the morning.
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
scarecrow
Post by scarecrow »
I ALWAYS break the bolt :oops:
rmattila
Post by rmattila »
scarecrow wrote:I ALWAYS break the bolt :oops:
The lonely socket in the outer corner should be slided sideways after prising out the two on the inner side: http://www.rmattila.com/images/remontit ... ikkeet.jpg
johnbird
Post by johnbird »
looking at the pictures of the headlights i cant decide if they are sided or not? it looks as if one spare headlight could be used for both sides?
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
Be careful when removing the headlight, i managed to break one of mine, some superglue & gaffer tape soon fixed her back up & currently still fitted to the car over 2yrs later, but annoying none the less.
johnbird
Post by johnbird »
i have just read your long thread and noticed you had broken one.its interesting the amount of suspension niggles you have suffered with.
do you know if one light fits both sides please? if it does i will get a spare one in.
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
rmattila
Post by rmattila »
johnbird wrote:do you know if one light fits both sides please? if it does i will get a spare one in.
No, it won't fit. LHS part # 95 587 064, RHS # 95 587 063.
johnbird wrote:i have just read your long thread and noticed you had broken one.its interesting the amount of suspension niggles you have suffered with.
:lol: Bit of a read eh :o Thats 3yrs ownership for you. I guess i might be unlucky, but others have suffered issues which havent cropped up on mine yet, so its all good fun.
As per rmattila regarding lights.
Post by Mothman »
As the BX gets older you will have lots of issues, its part and parcel of owning one but you will always get great help from members of this forum.
Some of the niggles will be an easy fix but a lot wont.
My last problem was 2 days ago but a minor one thank heavens, it was the first problem since the MOT last March. Am now waiting for the next one, a long wait may it be too i hope.
johnbird
Post by johnbird »
this is i think my fifth citroen.first bx but i adored my cx 8 seater famille. had two axs and a 2cv which i hated,nasty gear change.i drive artic trucks for a living.if its got a clutch i pretty much have a licence for it-atlas cranes included-but the 2cv was dreadful.............
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
The plastic headlight mounting sockets get brittle with cold weather (and age) so warm water over them helps if you are taking the lights out in winter.
