tzd rear window wash switch
tzd
Post by tzd »
Hi All,
I have a tzd which has a weird quirk. The rear window wash/wipe switch won't stay on if i press it in the washer starts washing and the wiper will do one sweep. Should it be like this or should i be able to press the switch and the wiper goes on intermittent ?
kevino
I believe that only the estates were fitted with intermittent switches. The hatches have a simple wash wipe switch, a quick flick of which gives you a single wipe. When you hit 30mph the window stays dry anyway
As above, i think some members have made the effort to retrofit the intermitten system from the estate to the hatch models, seems quite a faff to me. You'll get used to it :lol:
tzd
rear window wash
Post by tzd »
Hi all,
I have the estate as well this is what got me wondering about it.
I think retro fitting would be a lot of hassle so I won't be doing that.
Cheers Kevino
KevR
Post by KevR »
Never realised that! Maybe that's one reason why when I converted the first estate to TD and used the interior from a saloon, I never did manage to get the rear wash/wipe working!
electrokid
Post by electrokid »
I've only ever had estates - pressing the switch halfway down operates the washer pump and sets the wiper running - releasing from that position stops the washer pump but the wiper continues for maybe 3 wipes then stops.
Pressing the switch fully to latch does not operate the washer pump at all and puts the wiper into intermittant mode - one wipe every 10 seconds or so and pressing the switch again to release the latch simply switches it off.
I would have thought that should be its normal operation - if it's different on hatchbacks maybe there's a common wiring problem that may have happened during build in the same way the drive to the heater blower full power relay got missed out.
If anyone local has a hatchback and wants to bring it round for me to investigate I'm happy to do that.
2002 C5 HDi SX estate
is it just swopping the switch or more involved? not that mine get wet or used in the rain mind.......
Matt H
Post by Matt H »
I imagine there's some relay trickery going on... Swapping the switch most definitely doesn't work. :(
electrokid wrote:Pressing the switch fully to latch does not operate the washer pump at all and puts the wiper into intermittant mode - one wipe every 10 seconds or so and pressing the switch again to release the latch simply switches it off.
They genuinely are different - the owners manual even highlights the difference. I guess the extra complexity for the estate was deemed too costly to implement across the board, when the aerodynamics meant it wasn't that necessary.
electrokid
Well I stand corrected - I feel a mod coming on - but not 'til the weather is a bit warmer :-)
electrokid wrote:I feel a mod coming on - but not 'til the weather is a bit warmer :-)
So you can do it whilst naked? :wink:
electrokid
:lol: :lol: :lol:
Well I have been known to take my holidays in Cap d'Agde :D
Brian
Post by Brian »
Well, my 1986 RD saloon had the full works, but the 1992 TZD does not!!!
They must have changed at some point, cost saving I guess.
Wooscary
Post by Wooscary »
My rear washer doesn't work at all. :(
Mine does, but only a dribble comes out :cry:
