WABTED! BX16v tensioner for the alternator belt
Leobx16v
Post by Leobx16v »
does anyone know of any places where i can get 1 of these or has anyone got 1???
ive tried citroen, pleiades and aep direct in scotland and all my local motor factors but i have had no luck :(.
Tension lug? Alternator slide?
On Service Citroen there's a pic but it's not listed as available.
Is yours broken or missing?
Welcome along by the way. How about some pics and info about you and your 16v..
x 103
All my valver engine parts tend to come from these lovely people;
http://www.fpsdistribution.com/
i dont think they sell direct to the public, but they are national so you might be able to find a local garage who deals with them.
unless your car has AirCon then it doesn't have a tensioer on the alt belt.
The alternator swings on it's bracket..
Unless I'm missing something?
Leobx16v
Post by Leobx16v »
cheers for the replies and yes it has air con and the tensioner bearing is breaking down and rather than a recon and poppin a new bearing into it i would rather get a new 'en, and i will get some pics up soon :)
1991 Citroen BX 16v - Red
1991 Citroen BX 16v - Silver
1992 Citroen BX 16v - White
Scrapped:
G650PGX 1989 ph.2 red BX 16v
G-VOT 1989 ph.1 White BX 16v
The alternator swings on its bracket, but the tension is taken up by that slotted piece of steel ( alternator slide?) underneath with a 90 degree angle in the end. This is what I thought this post was referring to.
If it is this piece - should be straightforward to repair or fabricate if you could get a pattern of course. I don't think it was used on other BXs but perhaps Peugeot 405 MI6 - or are they even harder to find these days?
Ah, you posted just at the same time. Doc was right re the A/C then..
I'm very jealous now! Lovely looking valver with AC..
The tensioner you require is NLA, however, you can use a cut down XUD cam belt tensioner bolted to the sump, there's a thread on here featuring said mod, although it's location and exact details escape me at the moment!
x 103
appologies, i miss read and though you needed a timing belt tensioner.
The item in question i believe is on the left here;
