mpg so far
johnbird
mpg so far
Post by johnbird »
just worked the bx mpg out over its first 1,000 miles.48.5 mpg on diesel.not bad for 20 year old td mostly covered between 70 and 80mph on the m1. the saab 99 is nearing completion and will take over from the bx as a daily driver.my last c900 saab would do 32 ish on petrol.looking forward to the power again but ill miss the economy.
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
Rich
Post by Rich »
I'm getting 33mpg from my Petrol 19 auto on a run but alot less on my daily commute. How does this compair with other 19's?????
'86 2CV Dolly
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
Matt H
Post by Matt H »
I was getting 27 on my commute, which is the worst possible mix of stop start/just about warming through, but managed 34 with a mix of this commuting, fast motorway driving and a 56mph run.
I reckon I could get over 40 if I really tried on a run...
Rich wrote:I'm getting 33mpg from my Petrol 19 auto on a run but alot less on my daily commute. How does this compair with other 19's?????
My 220k miler GTi Auto does 34 on a run but I'm doing well if I get 21 mpg around town.
johnbird
Post by johnbird »
My wifes saab aero is doing 19 on her commute. Fun though.
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
Matt H
Post by Matt H »
I used to run a Saab 9000 CS Turbo, and my dad's Abbott Racing tuned 9000 Aero was better on fuel :shock:
Post by kiwi »
When I saw this thread I figured it would not be long before it became the "I am getting xxx MPG" :lol:
Anyways I am throwing my book out on calculating mpg or more correctly mpl or in my case kpl :lol:
The reason is because the Odometer/spedometer readings corrupt the data wih inaccuracy. By as much as 13% in the vehicle fleet I have :shock: Even the two BXs are out by 10kph resulting in 1 km per 10 differance. All good stuff huh! :D
speed, distance, enviroment eg weather, terrain, traffic flow and now accuracy come into how close your going to be to those official fuel figures.
In this day of higher petrol prices (been saying that the last 20 years :lol: ) we try to get best bang for buck. The BX still even though its an old car is able to achieve modesty for its size and weight.
Post by kiwi »
Goverment Fuel Figures
BX19 petrol carb Auto Urban 29.7mpg 56mph 46.3mpg 75mph 37.2mpg
ironically the Manual is just 0.8mpg better at 56mph than the Auto box at 47.1mpg other than that they are a match.
My 19TRS averages 11.05kpl around 32mpg, in theory with it being a open road trip and no traffic maybe one or two cars/trucks to pass on the passing lane :) I should be getting better. However the terrain being undulating a a vertical height change of about 400metres in 20kms kind of has a big impact.
The 19TZS averages 9.2kpl around 26 mpg :shock: which is kind disturbing even with the Aircon off but now I found out its got a 10kph speedometer differance to the TRS it dont feel so bad probably nearer to 29mpg? If it was not for the lack Aircon, leaky sunroof and difficult cold starting I would be using the TRS more.
Our Mitsi Galant rocks in with 11.12 kpl also runs on the cheapest grade of pertol sold here. But then since installing a GPS in the car discovered its speedo out by 7kph the opposite to the TZS so probably knock that down to 10.34kpl.
Cost wise for us the BX more expensive at the pump being on the higher octane rated fuels although that balances out somewhere along the line.
lucky rich
Post by lucky rich »
:D Chuffed to nuts with my 18 yr old 19txd,,,,,its got to be averaging close to 50mpg just general driving ,towns & fast roads,
Who said you need all this modern computer run rubbish,,,, :D .
Hi there, welcome aboard. That is good. You're right; who needs all the modern stuff? :)
Brought the valver home to Lancaster from Soton last yr when i bought her off ebay. Mainly m-way and dual carriageway. Guestimate at 40 mpg. Mind you didn't take her much above 65 mph! :oops:
mds141 wrote:Brought the valver home to Lancaster from Soton last yr when i bought her off ebay. Mainly m-way and dual carriageway. Guestimate at 40 mpg. Mind you didn\'t take her much above 65 mph! :oops:
Southampton? Which one did you buy then? The white one?
Aye. Just picked it up from the bodyshop today after having the sill to rear arch's repaired, bumpers resprayed and general tidying up. Looking good if i say so myself. 8)
