OIL LEAKS! (oh how i love them)
Leobx16v
Post by Leobx16v »
well tonight after work i decided to get the bx in the garage to start fixin and finding all my oil leaks :) and tonight i fixed the engine oil leak which was leaking from the rocker cover gasket and it was fulll of grit at the back but i sorted it, then there is the rest of the leaks :cry: i have lhm leaks on the front sphere, and flow valve and regulator is leaking and the bearing seal on the hydraulic pump is going haha. then i have a tiny gearbox oil leak round the speedo drive but apart from that its pretty good. And i wonder does anyone have a lwak free BX or is it a myth?
1991 Citroen BX 16v - Red
1991 Citroen BX 16v - Silver
1992 Citroen BX 16v - White
Scrapped:
G650PGX 1989 ph.2 red BX 16v
G-VOT 1989 ph.1 White BX 16v
johnbird
Post by johnbird »
my drive is so stained in lhm fluid from the fractured pipe fault its hard to tell.i have a regular spot at work and so far so good i havent got any oil leaks as yet. is it compulsory that it leaks or only general?
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
Leobx16v
Post by Leobx16v »
i think in general the bx's i have seen have had leaks here and there haha
Scrapped:
I'm g0ing t0 tempt fate here and say I have n0 leaks 0utwards, but still haven't fully tracked d0wn an ann0ying rainwater leak!
Post by kiwi »
If I get a leak in any vehicle and park it where I do when I am working and it leaves a trace on the ground all hell brakes loose. Compared to the BP Oil spill a small drip of oil , gearbox fluid, lhm etc or a overly smoky exhaust is a major national disaster to the powers that be.
rmattila
Post by rmattila »
None of my 3 BX:s (4 from this Wednesday, it seems.. beers ) currently leak LHM. The Wife's Break had a real annoying rainwater leak since I bought it in late 2005. Initially thought it was a faulty bottom plug (see pics), but fixing that didn't quite fix the problem though. Finally discovered a little dent on the driver's door frame that guided the water in the wrong direction on its way down the frame. Took 5 min to fix but over 3 years to find out how.
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
TZD is bone dry now I've done the rear crank seal + fixed the seaping LHM out of the regulator, need to fix the same LHM seap on the TGD to make that bone dry. :)
I've got similar on my 16v but owing to limited access to the regulator I think the radiator will have to come out for proper investigation which is why I haven't dealt with it.. yet. It drops a bit of oil, a bit of LHM and a bit of gearbox fluid for good measure. Apart from that it's fine!
rayfenwick
Post by rayfenwick »
Defender110 wrote:TZD is bone dry now I've done the rear crank seal + fixed the seaping LHM out of the regulator...)
Shh! It might hear you, and take it as a challenge :D
Ray
www.citroencarclub.co.uk
I thought in most cases if an elderly Citroen stops leaking, that means it's empty.
rayfenwick
DavidRutherford wrote:I thought in most cases if an elderly Citroën stops leaking, that means it's empty.
:lol:
Ray
Amazingly enough mine is actually free of leaks currently AND in daily service.
Watch it FAIL tomorrow.
Mine occasionally drips LHM from somewhere near the front height corrector (1 top up every 3000 miles seems to keep things flowing), and when working hard it'll push a small amount of coolant past the bleed screw on the heater pipe, but other than that it's fine. Amazingly, I don't even have to top the engine up between oil changes - not bad for a TU engine with 146k on the clock!
B-Hive
Post by B-Hive »
Putting the comment curse on here but the TRS is Driza Bone (excuse the Australiana)
The GT is fluid tight albeit the soon to be repaired PS pipes that have a few drips
..having said that I have just replaced the gearbox oil and cracked open the two drain plugs..so kinda anticipating some drip from non renewed copper washers..but that potentially happens with any car.
LHM leaks (or not as the case may be) are the litmus test here..I can kinda proudly say my 26 year old cars leave (very soon) no trace of their presence.
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
