On the look out...
On the look out...
If anyone's visiting a Citroën breakers....
...please check if they've got a Synergie? I'm after the bit of trim that goes in front on the rear arch (passenger side); it'll be a grey block of plastic about 5" x 4"? And, if they're in reasonable order, a pair of weather strips from the sliding doors (the bits that stop too much water getting in between glass and door slot - some call them 'scrapers?')...
Gibbo2286
Post by Gibbo2286 »
I can't help with those bits Phil but I do have some new bits for Synergie in my store room if you're interested. Gibbo.
Well I am interested in the bits I mention and also, whilst I'm at it, a parcel shelf in grey. Would it help if I posted some more information as to what I need?
Gibbo2286
Post by Gibbo2286 »
Might be better if I looked out the stuff I have Phil and posted it on here. I know there's what would be a very expensive sliding door fitting, the bit with wheels that fits under the door for it to roll on, maybe some door stop blocks and electrical contacts. Gibbo.
Sounds good. Ta! Phil
messerschmitt owner
Post by messerschmitt owner »
do you need a set of wheel trims (I have a spare set of XM ones) - the ones on the green car
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Thanks, Campbell, I am holding out for some Synergie ones - or a set of Synergie alloys, but they aren't high up on my list of priorities! The ones on there are brand new (the seller put them on) and although not 'authentic' they do a pretty decent job for now :)
KevR
Post by KevR »
May be of no use to you at all, but I have a genuine and boxed Citroën accessory for holding a bicycle in the back of a Synergie – slots in place of a seat rail and holds the bike upright by its forks (front wheel removed). Had planned to adapt it to fit the BX, but turned out not to be necessary in the end.
Well! Funny you should mention that. Would you believe I was planning doing some cycling along the Normandy coast one day?! :lol: But whether I will have the synergie with me at the time is not guaranteed... But I'll come and see you this year, in the Summer maybe, as I am planning a Normandy excursion anyway...
KevR
Post by KevR »
Cool - we've got the Tour de France passing by near here early July...
