Oil Query
Oil Query
Is it possibile to change the oil and filter TOO often. As the oil contains a detergent agent would changing the oil say every 1000 mls do more harm than good.
- x 94
You should change it every 6000miles, or every year. When a car is sat around, condensation can build up in the breathers etc (I know mine does) so the oil gets affected pretty easily. For the cost of doing it once a year, it\'s no real ball-ache either.
(Says the bloke who hasn\'t changed it since 2008!)
Cheers. For the sake of £15 worth of oil and a oil filter i consider it the cheapest and most important piece of maintenance you can do to any vehicle.
Isn't it also true though that when the car is run for a while at temperature, then this drives out any moisture?Kitch wrote:When a car is sat around, condensation can build up in the breathers etc (I know mine does) so the oil gets affected pretty easily.
This seems to go hand-in-hand with the mayo question that you'll see it on the around town runs in the filler but if checked immediately after a longer motorway run it has usually dissapeared.
