grim outlook for the GT
B-Hive
Post by B-Hive »
Hi all
In the process of working out the extent of my HP pump rattle I removed the drive belt and fired her up. Certainly a lot of the racket had gone but.....
Long story short.. there is quite a pronounced rattle/din coming from the top/middle of the engine, more so than just valve clearances. So as the HP pump is tired as is the clutch and the paint work on the car is shot and doesnt warrant much spent on it, I may have come full circle and break it up as originally planned.
So before I do something I may later regret, any words of advice.
I know that the engine has been abused as I think the poor ol' car was used as a paddock basher in its later years. From my experience its the sort of rattle that would make you walk away from buying a car. I didnt pay much heed to the engine when I bought it because I was just intending to use it as an auto to manual conversion donor.
I know these engines are quite hardy and rarely need big end/crank bearing work, but what about the higher up? like the gudgeons or little end bearings.
If it is "just" the valve gear, is it all interchangeable with a 1.6 head (which I have a spare) and is there any way of testing to make sure what is coming off is the actual problem?. Or is there an oil feed issue that may be starving the head?..last question ..does the valve gear fail catastrophically or will it just get louder.?
I appreciate that there are many variables since you cannot actually hear the rattle but input is appreciated before I lower the hatchet on the GT..
Thanks
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
Post by ken newbold »
You could just stick another engine straight in, maybe a diesel one :)
B-Hive
Post by B-Hive »
ken newbold wrote:You could just stick another engine straight in, maybe a diesel one :)
or....i could just install a permanent parachute out the back...same result..JK
Okay I have just dismantled my spare head to work out how it all goes together and functions. This head is kaput however it has shown me that it seems that the camshaft lower bearing surfaces are machined into the head. So if these surfaces are worn i guess that it requires a recond/swap head to fix any camshaft bearing issues...correct? also there is a little oil feed tube with removable filter in the head (only removable with head off) so if that is blocked I'm guessing it s a head off job unless you can reverse flush it.
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
Hahaha @ parachute!
Just bang another XU9 in it. New gaskets, belts etc. It is a project afterall!
NOOO not a diesel, keep it as it should be, rebuild the head and see how it goes. They arent the "quietest" of petrol engines at the best of time fitting an oil burner will be even noisier!
Jayboy
Post by Jayboy »
If you'd known this before i scrapped the TZS estate last year I would of happily donated it to the cause. It got scrapped due to rampant corrosion and general scruffiness, not mechanical issues.
Personally I'd transplant from another 19 petrol. I'm sure a rotten one with good mechanics will turn up cheap. Don't break her!! :(
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
It doesn\'t just have to be a BX either. 405 1.9 carb engine, some early injection models aswell I believe so possible even a 205 GTi. In fact, get a late one, bit of fettling and you\'ve got a big valve head upgrade! 8v\'s are always cheap these days.
Post by kiwi »
Hey guys if memory serves me 2BXORNOT2BX is in Australia!!!
There must be plenty of Pugs out there actually I know there are that an engine could be used from if its worst case damge.
B-Hive
Post by B-Hive »
Thanks for the words of advice...I removed the camshaft bearing top halves to have a look, and they are a little worn but nothing that would seriously contribute to the rattle I'm getting..The more I listen to it the more that I am sure that it is a worn or damaged big end.
In Australia we don't really have a ready supply of engines as cars don't tend to rust here but resale values are so low and backup is poor for BX's that owners get reluctant to spend any money or time so they tend to suffer mechanically.
I'll investigate a suitable swap out giving the GT a stay of execution or I may store it until something comes along..
BTW are there internal differences in the GT motor that give it more torque than the "standard" 1.9. Why I ask is that the TRi gives out 103HP and about 140nm torque (with injection) wheres as according to my research the GT motor (with carb) gives 105Hp and 161Nm torque..
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
frog
x 12
Post by frog »
Hopefully you can find another engine for it. If the shell is straight it would be a shame to see it scrapped. Where are you in AUS?
There should be enough wrecked 205/405/other BX's to be able to find another engine, they occasionally come up on Aussiefrogs for less than 500.
Maybe you could find a TRi 122, or TZi motor, you could retain the carb. In my old GT I had a DKZ (TRi 122) head on a DFZ (TRi) block giving it 10.5:1 compression, which was very fun.
There are not enough mk1's in Aus. I'd store it for the time being if you have the room, don't scrap it!
1989 Citroën BX 16v
1993 Citroën BX 16v project
B-Hive
Post by B-Hive »
frog wrote: Where are you in AUS?
I'm in Canberra, where abouts are you?
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
frog
x 12
Post by frog »
Damn, I'm in Brisbane. Would have been nice to organise a BX cruise.
1989 Citroën BX 16v
Kevin B
Post by Kevin B »
How did that work then?
Because in UK the 1905cc multipoint fuel injected engine (that you would typically find on a BX TRi/Tzi estate) has an inlet manifold porting arrangement on the cylinder head which is not compatible with the inlet manifold from a 1.6 or 1.9 Carburated engine.
Kevin B
Post by Kevin B »
Also I am interested to know what you had to do to raise the compression ratio from the standard 9.2:1, to 10.5:1 (which is in excess of the 16v D6c engine which has a CR of 10.4:1).
Engine particulars for the BX TRi estate:
Cylinders: 4
Valves per cylinder: 2
Capacity: 1905 cm3
Bore x stroke: 83,0 x 88,0 mm
Compression: 9,2:1
Max power: 90 kW (122 hp)
Max power RPM: 6000 rpm
Max torque: 150 Nm
Max torque RPM: 3000 rpm
Fuel system: multipoint injection
Engine type: sohc
Stinkwheel
Post by Stinkwheel »
Odd point maybe, but arent big end easier to deal with than a rattling cam?
Am i right in assuming BX engines are the same as most, i.e. sump off, crank caps, get at rods and big end shells, swap, reassemble?
Or am i over simplifying?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
