One big problem at the moment, and i'm wondering if i can avoid having to spend at the garage, is starting the thing
So mine starts absolutely fine when hot. But is it a nightmare when cold. I have to crank it solidly for literally a couple of minutes before anything happens. It's a good job it's got a strong BMW battery in there, prob the reason it was fitted to be honest. And once started it runs at a high idle, about 1500 rpm for a bit and then after a while sometimes a low idle, making it cut out at roundabouts, that sort of stuff! Once it's warmed up it's great.
Where do i begin?
The garage says about an hour to test and setup the carburettor + choke situation.
