Front & Rear curly Brake Pipes
Are these the exact same one's that will fit all models? Reason for asking is that i've got some which came from a valver & wondered if they'll fit either my txd or tzd turbo?
I've not had time to inspect them yet, so i'm reluctant to use the psgr side rear one to replace the bust one on my txd, does anyone know the part number & price please?
rmattila
Post by rmattila »
If neither has ABS or 4x4, the pipes should fit. Otherwise it gets a bit more complicated.
Part no:s for non ABS&non 4x4 are:
Front left 95 596 539 (length 500)
Front right 95 596 540 (length 1100)
Rear left 95 567 450
Rear right 95 567 451
(I suppose they're the same for right/left hand driven models.)
I usually just take the old pipe off and use it as a model to make a new one from standard 3,5 mm pipe.
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
I presume all 16v's had ABS, so these won't fit my non abs txd, good news is that they'll fit my tzd turbo which does have abs :D
rmattila
Post by rmattila »
The rear pipes should fit even between ABS/non ABS (as long as it's not 4x4, where the RHS rear pipe is different). In ABS models, the front pipes are made of 4,5 mm pipe:
LHS part no 96 042 337 (length 825 mm)
RHS part no 96 042 339 (length 1600 mm)
(And of course, at front it makes no difference if the car is 4x4 or not.)
Aha, many thanks for the info Riku. I haven't had a chance to inspect the pipes, so i won't risk getting it fitted just incase....I'll get the garage to order me a new one.
