Frequently asked technical questions and common modifications/improvements
• Page 1 of 1
KevR
Postby KevR »
Right, here's the list of oil filter equivalents for the original (larger) fitment, which was originally listed for all BXs except early BX14 (to june 1988) as well as for early Xantias and many CXs. Taken from a 1996 Purflux catalogue so some refs may be out of date, but might be handy when looking at old stock at an autojumble or ebay.
Might be worth a mod cutting and pasting this into a new thread in the Tech FAQ? Then if it gets added to, it's easier to find.
Purflux LS 468A
Champion F104
Ford 5011788 (probably others too)
Lautrette EL H4104
Crosland 2031
Fram PH 4703
Mann W815
Motorcraft EFL 273
Peugeot 110951/110967/110968 and others
Purolator L14619/L17620
Bosch 0451103089
Citroen 95580482
Citroen 95580483
Citroen 93516538
Citroen 95495621
Citroen 95495622
Citroen 95495894
The only refs I have for the later version so far are:
Purflux LS867B
Mahle OC31
Anyone got any more? Can we do something similar with fuel and air filters, and any other parts which are likely to be shared across models?
Using the parts catalog and in the search field "Citroen xxxxxxxxx" (X being the numbers) it give what makes use that part. Normally Pug and Citroen, but there are some parts that other makes use too.
Like the GTi 8V pressure regulator, it's the same used by FIAT Uno Turbo 1.4 Mk1
Cross references helps specially when you can't find the oem parts and in places where BX and its parts became rare.
Citroën BX GTi 1993
. XU9JAZ engine, ZF 4HP14 Automatic gearbox
. Leather Seats, Air Conditioner, electric mirrors, windows and sunroof
. "16V type" Speedline Rims, "Ducktail" spoiler and rear vents
ORGA 5219 (February 22, 1991) - Made in Uruguay
Hot steamy night alone, I wait for you ♫ Cold brittle morning alone and I cry for you ♪ And when you finally call ♫ You cloak your moves in the shadows ♪♫♪
My Cars: 1999 Xsara LX 2.0HDI (90) Hatch - Fern 2002 C5 2.0 HDI (110) Estate - Jasmine - SORN 2011 Mini Cooper D Clubman - SOLD 2016 Mercedes A180D Sport - Auto refinement 1992 TZD Turbo - Bluebell - SORN 1992 TZD Turbo Estate - SORN 1991 Gti 16V - Blaze - crash damaged, will get repaired - SORN 1990 Gti 8Valve SOLD - looks like it's been scrapped 2002 Mini Cooper S - SOLD - i miss this car 1992 TXD - Scrapped in March 2014 1988 CX 25 GTI Turbo2 - SORN 1996 - AX Memphis 1.5D - Dream - SORN
Cheers Vanny, that was just the info which i was after I presume they can still be purchased from citroen?
