cylinder head interchangability
rabbercelt
Post by rabbercelt »
does a non turbo 1.9 head fit a 1.8 turbo engine-any advice?
Nope.
well, yes, it will physically fit, but it wont last long!
djm666
bx heads.
Post by djm666 »
why wont it last long. it is only the size of the ports your changing i presume.
how can that make it so it wont last long?
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
turbo and non turbo heads are not the same metals, and moreover the turbo head is somewhat stronger in the casting.
djm666
diesel heads
Post by djm666 »
so you could fit a head from a turbo diesel xantia. then just used the standard 1.7 td head gasket as required.
sounds like a plan.
the ports are the same size 1.7 or 1.9. so all the difference is in the casting. i will have to look into that.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
Kevin B
Post by Kevin B »
docchevron wrote:turbo and non turbo heads are not the same metals, and moreover the turbo head is somewhat stronger in the casting.
So if you didnt know what engine they came off, how is it possible to tell the difference?
scarecrow
Post by scarecrow »
There must be a serial No. embossed somewhere
djm666
diesel head
Post by djm666 »
you would have to sling it on and go for it.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
