Not exactly a burning issue, but in the absence of any other problems (that's cursed it!) I'd like to get my boot open warning light working. All the wiring is present into the boot lid (brown 2 way connector) and if I short the two wires together the symbol lights up on the display.
Problem is there is no switch on the latch mechanism, and no evidence of where one might fit. Has anybody else got one that works, and if so do you know what it looks like? Is is it a case that the wiring was fitted but not the switch? (I believe that no BXs had an operational seat belt warning lamp, at least not over here so it could be a similar situation here).
Boot open warning light
- x 27
Gibbo2286
Linegeist
Well, it's been like that since at least 2004, so no desperate rush I suppose! There is definitely no switch anywhere near any part of the lock mechanism, so it looks like it's been replaced with a standard one at some point. Probably by the same person who lost 50% of the screws holding the trim on, and replaced them with a mismatch of different headed screws.
Thanks Bob, I will take you up on that offer
I'll keep an eye out for a Bosch pump and injectors I can bring over for you!
