Belts
Belts
I have just acquired a 19TXD (with air con) and with it came quite a few spares and new parts. Including a selection of belts.
Can anyone help me identify them?
Citroen part numbers:
5750.H1
91 536 298
91 536 303
Plus a Gates 48341 micro-V.
In addition to the belts I have a clutch cable M LECOY (manufacturer) 30225
Gibbo2286
Post by Gibbo2286 »
5750.H1 = 1580L & 1905L up to RPO No 05284 not for GTi Alternator belt.
91536298 = GTi up to RPO No 04223 Alternator belt
The others are not listed in either the Citroen or Gates catalogues that I have.
Don't know about the clutch. Gibbo.
messerschmitt owner
Post by messerschmitt owner »
I just pulled a working aircon pump off a 93 XM. DO you need a pump?
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
No thanks, Campbell; the air con works fine. It's just that I need to replace the belt at some point before the summer.
Thanks Gibbo for the info!
I might be able to match the other parts to what's actually under the (steel) bonnet
