Not BX, not even a little bit - Land Rover wanted
KevR
Post by KevR »
Bit of a long shot but you never know.
I'm after a complete Series 2A or 3 LWB Landrover as a project. Ideally a pickup, would take a hard top, not interested in Estate/Safari. Ideally something running and complete rather than a complete basket case. If it had a short MoT so I could drive it home that would be perfect but it's not the end of the world if it hasn't. Needs to be standard engine/trans as it's to bring to France and modified vehicles are a pain to register.
Oh, needs to be cheap, and probably no further North than about Leicester.
Anyone know of anything?
Cheers,
Kev
paulwitchard
Post by paulwitchard »
You're in the boss's good books then! :lol:
Paul in Normandy - BX 1992 Millesme 1.9D, 1999 Peugeot 806 2.1 TD (the Bus) - gone bang on the M25, in a scrapyard somewhere in the SE of England, 1985 Visa Decouvrable, 1990 Land Rover 110TD (Great Uncle Bulgaria),1999 Isuzu Trooper, 1991 Hymer motorhome with Peugeot J5TD power, and a shedfull of mopeds!
KevR
Post by KevR »
She doesn't know yet, so if you don't tell her, I won't either....
But the 2CV race car went to a new home yesterday, the Cady went a couple of weeks ago, and the AK is, inshallah, on its way to the States (if Jeff hasn't cocked up the paperwork). So Ijust thought I'd make a few tentative enquiries....
Speaking of new vehicles, I hear you've got something else too...? Or is that the Visa Club that's popped up in your list?
Might be over your way at the weekend - any chance of borrowing your pointing gun?
paulwitchard
Yes the 'new' Visa has turned up - some pics on the Visa forum - it may need a new heat exchanger, not sure if they are the same as a 2cv, perhaps you could have a look and let me know.
You're welcome to try the pointing gun, we've never managed to get anything to come out of it - I think a big icing bag might be a better bet.
KevR
Post by KevR »
Not sure if the heat exchanger's the same as 2CV but will try and find out. If it's leaking fumes into the car it's just as likely to be a leaky head/barrel seal and might be sorted by torqueing the heads down.
Pointing gun's only for forcing some mortar in between ome oak beams aboe a doorway, rather than for any amount of actual pointing, so it might be ok - worth a try anyway.
paulwitchard
Have found out the problem, the front part of the 'bellmouth' has corroded away a bit, so its even more of a s*d to fit.
