I have 2 spare HP pumps one internally tired and one purportedly with a cracked casing but good internals..How easy is it to transplant the internals from one pump to another??
If easy enuf this could be a low cost solution to the GT's poorly pump..
Also whilst on the issue of pumps (again!!) ..I have finally managed to tune the GT and got a nice slow slow and steady idle (700rpm)..
However at this speed the pump's noise is quite a distinct cyclic knock..
question....i have heard tell that a flat accumulator can have a nasty impact on a pump and can crack the case. I'm thinking the noise I'm getting is just the sort of racquet that might well cause a crack eventually..
anyhow just a thought
swapping HP pumps internals
B-Hive
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
Muiruri
It can be done.http://www.bxclub.co.uk/forum/viewtopic.php?t=12007. Watch out for the two seals. fond of leaking.
Sammy Muiruri
1988 BX 19 GTi
1976 GS club
1988 BX 19 GTi
1976 GS club
JayW
- x 13
- BXpat
There was a bloke selling the complete pump seal set on ebay.de last week for €10 inc. postage in Germany. I can ask him if he'll list it again if anyone's interested and post further afield.
Muiruri
- x 116
Kevin B
As tempting as that item is, from my limited interpretation skills, that seal kit looks like it is intended for the 6+2 pump, which is only found on the Xantia and XM.There was a bloke selling the complete pump seal set on ebay.de last week for €10 inc. postage in Germany. I can ask him if he'll list it again if anyone's interested and post further afield.
Otherwise an excellent use of the scissor jack to remove the pulley, and split the casing off the pump
