19 n/a diesel idle
19 n/a diesel idle
What is the correct idle range? Mine seems a little high at 900 rpm - and 1050 when cold.
Sticky throttle cable the problem if it is?
1050 when cold, assuming the cols start actually works (which is rare!) is fine, it should come down to 850 / 900 as it warms up, so yeah, nothing much to worry about there.
Excellent. Seems to be running like a dream. Not much puff at start up from cold and pretty responsive. Well pleased.
*mind you, turning the air con on doesn't exactly boost power* lol
Philip Chidlow wrote:*mind you, turning the air con on doesn't exactly boost power* lol
Show off! :P
KevR
Post by KevR »
Philip Chidlow wrote:Excellent. Seems to be running like a dream. Not much puff at start up from cold and pretty responsive. Well pleased.
I've got air con in the MX-5. Turning it on makes causes no noticeable drop in power.
Mind you, it causes no noticeable drop in temperature either – it's never worked since I had it!
Same as my TZI and SD1 then....... :lol:
