For a while my drivers side electric front window has been unavailable due to the fact that when wound down, the window sticks in place rather than sinking and the support leaves it behind, then eventually it frees itself and does a nose dive into the door, missing the support and having to be extracted and put back on the support by hand.
Once back on the support it will wind up fine but immediately stick when the motor is wound down still.
Anyone know why it's doing this? I want a nice open window now the weather is getting nice.
edit: reading a couple of other window related threads it seems there should be some kind of channel attached to the glass. My window glass has no such channel so I suspect it has detached and is floating inside my door frame.
Window sticks and drops
Boxwolf
1992 BX TXD Turbo
I suspect the metal channel that grips the glass has corroded away and needs replacing.
Mk 1s were aluminium and Mk2s were steel, hence being liable to rustworm attack.
Had to replace mine last year part, aluminium still available from Citroen as its still used in many current models. You will also need the rubber strip that runs the length of the glass base. Without it the window will release from the metal channel after a short while and the problem will reoccur.
Boxwolf
Won't the rubber strip still be there from the old one?
What daft clot decided they were going to change from aluminium to steel anyway? I bet mine has rusted away, that's going to be a pain in the pocket if it has. I'll have a look inside the door when I next have time and good weather (the two rarely occur simeltaneously though)
1992 BX TXD Turbo
Boxwolf
Boxwolf
Boxwolf
Hi bud,Boxwolf wrote:No metal doohickeys floating around anyone's parts bin? bother. Well can anyone point me in the right direction for getting one from a parts supplier? I don't even know what to call the thing when asking
just found the rubber strips, let me know when you want one. Also found the spare ally bit to do the passenger side next Sunday,sorry its not going spare, busy waxoiling the rear end of the motor today.
As for what its called, i reccon window winder chanel is as good as anything, if you explain to someone at your local Citroen main dealer, ime sure they will get the gist of what you want.
Boxwolf
Hi Boxwolf,Boxwolf wrote:.........Well can anyone point me in the right direction for getting one from a parts supplier? I don't even know what to call the thing when asking
It's item #2 O/E part number :- 95 633 346 (Window Channel) .
(Click thumbnail for larger image)Above image copied/pasted from THIS thread (for ref. ) I hope it is of help to you/others !
Boxwolf
