My BX came with a retro fitted sun roof, just the flip up type with 2 height settings but its quite noisy to use.
Anyone with any experience with the sun roof reflector? Does it improve things as much as the side window ones?
I have been looking at the stick on type on feebay. Will they stay 'stuck' for long enough.
Ta
Sun roof reflectors
- x 27
Deflectors for the 'standard' BX sunroof clip on. The accessorie 'pop-up' sunroofs are narrower AFAIK. So after-market universal is the only one you could use. However, they only really cut out noise and buffeting from a sunroof when it's slid back or closed (as the seal can produce wind noise).
Not sure I'd trust a stick on one personally. But I guess they're probably fine and fit for purpose.
