The exhaust centre was a joke - I actually saw the fitters fighting over who drew the short straw and had to work on "That Bleedin' Complicated Citroen Thing Outside!".
When they eventually decided they'd got the right exhaust part (2 attempts) which they had to order each time, and then remembered they needed a fitting kit (attempt #3) requiring yet another order
When I finally rolled off their forecourt nearly 4 hours later and eighty quid lighter, I found the steering was making a funny noise when turning onto full right lock ............... when I get a mo' I need to find out what they've done. It was one of those workshops that hide behind the Health & Safety bollocks to stop you entering their work area and actually seeing what the hell they're doing with your car.
However, the reason for this post is to ask a question - on getting home and running the car up onto the ramps, I've discovered that the downpipe to manifold flange has been bolted up solidly with 4" long machine screws and no springs (but about 2lbs of bloody exhaust paste). Now I was under the impression that the exhaust on these cars was supposed to flex at this joint, and the asbestos ring was there as a mechanically flexible gas seal which was held in compression by the pre-tensioned springs.
Before I go back and disembowel the chimps at the exhaust centre, is this the new way to fit exhausts to BX's now - or will the pipe develop a stress fracture in due course? I know the car feels harsher then when I took it in this morning..........
