For sale black TZD 1.7 td now sold now on ebay
I have for sale my black tzd hatch. 163.000 miles MOT till Sept Tax end of july with the boch pump in it.
As i have just got another bx. And still not got a job so need a bit of money
Body work is in good order It has a towing pack on it. So it has 2 fans. All the electric windows work. Been waxed oiled. New timing belt on it and igniters. LHM fluied has been replaced. 2 new back spheres. Accumulator replaced. Has a New Rev counter sencer. Towing electrics has been fixed. Gear box oil has been replaced. Cluch feels good.Plus other litle things has been done to it. Like Washer motoers arms. Bulbs replaced wiring been sorted out. Stuff like that.
All the jobs have been done. With in the last year by CITROEN SPECAILSTS Spent a lot of money on it.
This what it says on the last mot certificate
Only refused on 2 little things
1 Offside rear break cable steering system has a tyre fouling a part of a vehicle
2 Offside Headlamp aim too high
Advisory iterms
3 Nearside power steering rams has slight seepage from a componment
4 Steering system slightly rough
5 Nearside front constant velocity joint gaiter deteriorated
6 offside front front suspension has slight movement at a wishbone pin or bush
7 Nearside rear radius arm has slight play in a pin bush
8 Nearside front brake hose slightly deteriorated
9 Offside front brake hose slightly deteriorated
10 oil leak
The other small bits are. The electric mirrors go only up and down. The boot lid is from a 16 valve. The passenger door is from a differnt car. You can only get in from the driverside. But the centrol locking works fine. And the door warning light comes on when the boot is up. The back windscreen heater doesnt work But it cleared ok when the cars warm anyway So its not all that bad. One of the pins has gone in the ignition barrow. I can take the key out when the engine is running. But i have tryedother keys and they dont fit so still sercure. Plus i think its a good thing in winter when warming up the car. Ill miss that
There are the niggly picky bits done.
Dispite it all its always started up first time. Never let me down.
Goes really well and quite fast.
Advisory iterms
10 oil leak
PAUL JACKSON
cosa 1.2 brezze 150 k had
http://www.carandclassic.co.uk/car/C225061
Hers some photos there might be some more on the way
Send me a pm on here
Thanks
Thanks
PAUL JACKSON
Hi Paul (As Request), click for SLIDE-SHOW or Photos below :-jacksun1987 wrote:.........................
Thanks
I hope that's all okay for you Paul ?
But IMHO I would have swapped your Speed-line Alloy wheel's over with the Red TXD steel wheels & trims at the price your asking for the TZD as your taking a big hit on what you paid for the TZD (Not including the extra monies you've spent on it since) as won't make much difference if some-one ones want to buy it !
Anyhow its your choice/car, best of luck with a quick sale and get the TXD taxed/insured ASAP !
Thanks for the photos. Yes i wouldnt mind keeping them but its all the messing around. Im sure once i get things sorted out i can find some better wheels for the txd.
PAUL JACKSON
No ones borthering with it. So im dropping down the prce. Im having the wheels swapted if its a low price.
Its just going to be sitting there doing nowt. Im working nite so sleeping in the day. Got no time for it. Ill reather give it to somone who can get it up to scrach
PAUL JACKSON
- ken newbold
Yep doing nites at the moment.
A place called staples a tissue factory.
I kept seeing 1 or 2 bxes. In the for sale wanted bit. What are round this price.
PAUL JACKSON
Still 4 sale?
Hi Paul
Is it still up for grabs?
Regards Richard
Regards Richard
What price do you lot think it should go for. I have a alternater now but it needs fixing on. It still starts up and drives. Unlike other cars on ebay and other sites. Where they arnt drivible with no tax no mot on them.
PAUL JACKSON
Paul !
I think you've set/asked for £350 from the revised title/post (Which is a reasonable price) with the normal steel wheels/trims, but IMHO if some-one offers a bit less I'd take it as you don't want to be spending more monies for MOT's etc. so I'd let some-one else take it on and give it some TLC, but that's down to you !
All the best with a possible sale !
Have you not PM'd Richard /\ yet ?aynako50 wrote:Hi Paul
Regards Richard
- ken newbold
Hi must be doing somthing wrong. Ie had 2 or 3 people intrested in it. Then they just dissaper. Im i being to honest
PAUL JACKSON
ITS STILL FOR SALE. ILL EVERN GIVE THE ALTERNATER WITH IT AS WELL. IM JUST GOING TO SWAP THE WHEELS OVER SO THE MICHEN TYERS WILL BE ON IT AS WELL
PAUL JACKSON
