air filter hose
rodney68
air filter hose
on my 1.7 tgd n/a diesel it has a cardboard hose from front of car to air filter,this hose has foam lining the inside of it and the foam is falling off,my question is at work we have lots of clear wire reinforced hose in this diameter,can i replace this with some from work as old hose has holes in it from new and is a smaller internal diameter ,will it make a difference to how it runs?
k reg citroen bx1.7tgd,vauxhall astra 1.6 16v,kawasaki er5 ratbike
It's pre filter so no it won't make any real difference to running and no the foam won't get sucked into your engine unless you take your air filter out. It's a cold air pick up pipe that's all, you could always drill holes in the stuff you have at work to make it the same.
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
How fashions change - now the chavs buy stuff especially to make the induction louder
Ray
www.citroencarclub.co.uk
Roverman wrote:Look on ebay, there has been one on there for AGES on a buy it now price.
what a chave
and they spend fortunes trying to make them sound louder,
when all they need to do is remove the foam from there air pipes
Brian
rodney68
