Item 1 - Clutch
The clutch is very creaky, which is getting annoying. It works exactly as it should as far as can be assessed, but creaks loudly on its upwards travel. I've tried my best to see anything untoward in the footwell, and under the car. Not sure where it all pops out in the engine bay though, or really what to look for.
Item 2 - Accelerator pedal
Possibly related, but I can't see any cracks in the pedal box. The pedal sits a bit wonky, pointing to the offside of the car a little and is a bit stiff and squeaky on its pivot. It felt like it was getting stuck on something like the carpet. I've had it off today and reassembled and it is a bit better/sitting a bit straighter, so maybe that's sorted?
Item 3 - harsher ride
Noticed the ride has got a little harder recently. All four corners still seem soft/rise back up when pushed down etc, so does this point to the accumulator sphere? Also, the car sinks fairly fast after turning off, so doseur? This is the main thing I'm wanting a garage to do.
Item 4 - oil filler neck
After my previous issues with this, I'm going to replace the old one with a new one, but it was such a bugger getting in there, it seems a good idea to remove a few bits to ease access. So, how easy is it to remove the fuel filter housing (this seems the bit that would make the job easier if it wasn't there). Also, at a pinch removing the part arrowed in the picture would give me some extra clearance, but what is it and can it be removed without messing things up?
4 by Wooscary, on Flickr
So, I appreciate any input, and apologies for the hefty diatribe. Thanks a lot.
Martin
