Noticed oil smell and leakage around the area of the cambelt side of the engine (dont want to confuse lleft and right here
Took off the cambelt cover and no sign of leakage in there so looks better than worse case so far. Conclussion from a mech who had a quick look is seems like the rocker cover gasket. I suspected the Breather hose split so double checked that and tightened the pipe.
After a short 50k drive the leakage became apparent again (no oil seepage onto manifold after the clean up)
What I did notice today was the bolt that looks like it holds down the rocker cover was a bit loose. Actually finger loose!
Anyone confirm that that bolt does indeed hold the gasket in place and could be the reason for the leakage? Off top my head I can not remember if oil can get out that bolt hole.
Thats problem number 1...further posts may follow.
