Hi Guys,
just a quick question ? Is the LHM pump the same all the way through the production life? I.E. is the same pump used through all models?
Kev
lhm pump
- BX Digit man!
demag
tzd
lhm pump
Hi Dave,
I had no idea of that !
I think the mark 1 Bx had a different configuration as to where the high pressure port is positioned but I didn't know about the cam belt pump.
Kev
Kev
It isn't just a car it is a BX and it's my BX. Long live the BX.
it would have been driven by a belt from a pully on the end of the cam shaft,
as the only direct drive pump i have seen on a hydraulic citroen, is on all the GS/A modles, as this was a single piston pump with a small conrod running on the oil pump drive,
demag
i have not seen a CX with a single piston direct drive pump either,
as far as im aware the CX had either a 5 or 7 piston rotary belt driven pump, dependant on year/modle,
i think some of the D's had some sort of single piston pump,
Is it possible to swap the pulley part of the pump over to another size?
ID's and I think some low spec later DS's had a single piston pump, as do the G range of course. I believe that some very early non-PAS CX's also had the DS/ID type single piston pump, although Dominic Weston should be able to confirm this.i have not seen a CX with a single piston direct drive pump either,
