Has anyone a spare T pipe or whatever you call it for the bit that fits on top of the reservoir cap.
T pipe bit for LHM Reservoir
Gibbo2286
JayW
- x 13
electrokid
Yes - I've got some of these available at cost + post - they weren't cheap though (I'll have to look for them and the original invoice).
Malcom (Citronut) has previously suggested that the T piece used elsewhere is cheaper and a better fit - probably good advice
2002 C5 HDi SX estate
KevR
This reminds me that my T-piece broke and as a temporary measure I just plugged the actual return pipe into the rubber on top of the LHM reservoir cap, and ignored the overlow pipe, which IIRC just goes into a void in the wing anyway. That was at least a couple of years ago and I don't seem to have noticed any deleterious results - any reason why I should change my mind and track down a new T piece to put it back to standard?
KevR
Good point – I'll get it sorted next time I'm under the bonnet polishing the inside of the radiator hoses...mat_fenwick wrote:To avoid getting points deducted in concours competitions?KevR wrote:any reason why I should change my mind and track down a new T piece to put it back to standard?
