Whilst inspecting the engine of the new 16TGS i noticed that the oil filler cap metal gauze/mesh was completly gunged up and almost blocked with old hardened oil and dirt. Looked disgusting and probably hadnt been cleaned for 20 years. 3 good soaks n scrubs later the petrol was still the colour of chocolate and so i have left it to soak overnight.
Would the breather cap in this condition have affected the vehicle's performance and should this be cleaned on a regular basis? Motor seems to go ok at the moment.
Gunged up oil filler cap
- x 27
Personally I ditch the gauze as the design of the filler encourages condensation (which is why you always get mayo in the cap, breather pipes, neck - especially if you do lots of short runs) as that moisture rots the gauze anyway. Can't see it does much: the intention is to catch vapourised oil I guess and let it dribble back down the filler neck. Can't say I've noticed a problem in any of my petrol BXs with it removed.
Rich
i belive its down to the gauze inside the filler kneck,
these being blocked also leads to mousture droplets forming on the underside of the rubber boot over the top of the carb,
which drip down and into the emulsion tube/jets inbetween the carb venturies,
you can strip and clean this gause, remove the filler kneck from the car and use a half inch drive extention to drift out the inner funnel shaped centre section, by putting the extention up through the bottom of the kneck and hold the body whilst tapping the extention on the bench/ground,
you will find a roll of gauze in between the inner and outter sections of the kneck,
pull the tack out that holds the roll together, unroll, clean in petrol then reassemble,
the other cause for mayo/gunnge in the breather system is if the rubber filler between the kneck and crank case is bent over or colapsed,
