Hi, I've a Citroen BX TGD manual that I'm breaking here at my work at Carnforth, Lancs, with cheep prices to clear it.
Engine with box, no leaks and can be seen running for £60. Overhauled rear arms with hubs, £50. Exhaust £10.
What you want, gives a return mail before it goes on E-Bay...
Anyone you know want parts ?
I can pass on details if required
Email Message to [email protected],uk
rhv100
Bx Parts
Hi Tim,
Are rear arms the same for all BX"s? If so I"ll take them.
I dont mind picking them up from Carnforth.....it was the location for
"Brief Encounter" so a chance to see a bit of history!!
Hope you are well
Best Regards
Richard
Hope you are well
Best Regards
Richard
Re: Bx Parts
As far as I know they are richard these WILL fit your car, I will pass on his details to you.rhv100 wrote:Hi Tim,
Hope you are well
Best Regards
Richard
Thanks
Re: Bx Parts
There NOT all the same !Roverman wrote:As far as I know they are richard, I will pass on his details to you.rhv100 wrote:Hi Tim,
Hope you are well
Best Regards
Richard
Thanks
The models which have ABS have an additional cast lug feature to mount the ABS sensor likewise the hubs are different too which have the reluctor ring fitted to them.
So if the donor ones are not ABS type and you need that type they'll be of no use but you can fit the ABS type to a non ABS model with no issues (as I've done in the past) !
Tim, perhaps best not to advise on technical issues if your unsure as some else mentioned recently too
Re: Bx Parts
Tim !
Read thro' the post and decipher the facts where does it state the Richard/rhv100 has a BX with or without ABS (Likewise the donor/parts vehicle)?
You may know all this info, but others (Like myself) may not
A question was asked and IMHO you answered it incorrectly, I corrected your answer its as simple/straight forward as that !
BTW ! I've no need to wind anything in, (as it not been wound out) !
Hope you are well
Best Regards
Richard
Roverman wrote:As far as I know they are richard these WILL fit your car, I will pass on his details to you.
Thanks
rhv100
Rear Arms
I"m sorry to have caused this spat! I suppose I should have made
myself clearer but the post was intended for Tim as a P/M who does
indeed know my car.
RX/BX.....Thank you for the infomation.
TIM.......Apologies Mate..Its an age related thing probably!!!
Now going back into the shed!!!!
Best Regards
Richard
indeed know my car.
Best Regards
Richard
pmh
pmh
