rear disc to change.
Preacher
It failed the mot on multiple problems however Tim sold me some new discs, great only problem being i cant get thosr caliper bolts undone plus have found that the n/s rear caliper leaks, a lot. Advice on the bolts plus where's best for a caliper would be appreciated. Thanks
1992 BX16 TXS - NOW back on the road
Do you mean that you can't undo the big 17mm bolts that hold the caliper in place, or those pesky 8mm ones that pass through the caliper and pads?
The 17mm's will just be very tight. The 8mm ones are a pain. If the caliper is duff just concentrate on getting the brake pipe out intact, then a long bar on the 17mm bolts with a good quality socket (6 sided preferred)
New calipers are hard to come by and/or expensive. Might be able to find you a decent second hand one.
or if they are still avalible here is price and part No.'s of seals and pad retaining nut and bolt for one calliper,
(1) piston dust seal/velt
95565090 PISTON SEAL 4.71 GBP 5.65 GBP 5.65 GBP
(2) piston presure seal
96995632 PISTON SEAL 0.57 GBP 0.68 GBP 0.68 GBP
(3) calliper body half seal/O ring
95587148 PISTON SEAL 1.40 GBP 1.68 GBP 1.68 GBP
5438691 CALIPER SCREW 5.20 GBP 6.24 GBP 6.24 GBP
0000693322 HEXAGONAL NUT 0.14 GBP 0.17 GBP 0.17 GBP
Preacher
many gratious thanks Gibbo, definately the cheaper approach now just need to get the 17mm bolts loosenedGibbo2286 wrote:If they're just leaking fit a new seal kit.
http://www.brakepartssuperstore.org.uk/ ... 16053.html
