Wanted AC Compressor
for the BX TXD. The eBay listing has ended (didn't have funds sufficient to allow me to buy that one - without causing 'upset') and although I contacted the seller I haven't heard back. Does anyone have a reconditioned/working spare one? Or know where I could get one from for a reasonable price?
May be worth seeing if you can get yours refurbed Phil?
Well I got a reply. They still have three in stock. So when I finally get paid I'll order one.
This presents you with an opportunity to do the full R134a conversion doesn't it as you're opening the system anyway? :D You can fill the compressor from the start with the PAG oil it needs for (R134a) lubrication. 8)
IIRC the other recommended things to do are:
(1) Replace the 'o' rings with green neoprene type for longevity.
(2) Replace the receiver/dryer which should be done anyway if the system is opened irrespective of gas used.
(3) Fit pipe-end conversion fittings for R134a
Once converted the benefits should be cheaper re-gassing more widely available from competitive firms.
DIY regassing is even available as halfords sell the R134a re-gas kits. In your case consider that for the time after though as a vac down would be wise after reassembly.
Any other quirks I'm sure someone will be along soon to mention.
:wink:
Absolutely, sir. My air conditioning chap will convert it to R134a when he fits the new compressor. 8) Hopefully next week.
Good note about the dryer... Didn't Tim get a new one of the 'Bay recently?
Philip Chidlow wrote:Absolutely, sir. My air conditioning chap will convert it to R134a when he fits the new compressor. 8) Hopefully next week.
I did Phil for a whole £5! :D
x 116
Thats got to be a real bargain Phil. £60 for a reconned compressor.
I put ester oil in mine when I did the 134a conversion a while back as it works with both the residual R12 mineral oil left in the system as well as the PAG oil usually used.
Roverman wrote: I did Phil for a whole £5! :D
Where from? I Have you got a link or supplier name?
Thanks. I just wanted to make sure. Why is postage so much? :shock: Ah well, can't really complain...
They're away until next week, so I'll have to wait.
Philip Chidlow wrote:Why is postage so much? :shock:
Because the eBay fees are calculated from the item sale price? Still, as you said, you can't complain at £12 all in!
