wanted: lhm tank t-piece, 16v dipstick and oil temp sensor
RobC
My Cars: 1991 Citroen BX 16v
x 30
Post by RobC »
anyone got any old ones of these lying around?
could buy new but will be expensive (dipstick £25 from spoox, sensor £30!) so thought i'd check here first.
not tried citroen yet...
1991 Citroen BX 16v
You should get the dipstick and old sensor from Citroen.
Mike E (uk)
Post by Mike E (uk) »
Hi Rob,
the dip sticks have been on ebay in the past.
Mike
Got my 16v dipstick off ebay. End piece is different ,yellow plastic instead of black, but the metal stick is the same length. IIRC £10.
RobC
x 30
Post by RobC »
thanks chaps. nothing on the 'bay at the moment but i'll keep checking.
1991 Citroen BX 16v
if it still avalible here is price and part NO. of the three way T piece union, which lives on the sub frame behind the battery, which i belive will fit the tank, and fit better than the original Y union on the tank cap as it will allow the pipes to come off leve,
5451210 RET TUBE SLEEVE 12.35 GBP 14.82 GBP 14.82 GBP
although the original Y union is priced a little less,
0000527014 3 WAY UNION 4.61 GBP 5.53 GBP 5.53 GBP
mountainmanUK
Post by mountainmanUK »
Dipstick eBay linky.......
http://cgi.ebay.co.uk/CITROEN-SAXO-XSAR ... 4a94a22921
Sorry for loooooong link....in a rush to get lad to school! :wink:
RobC
x 30
Post by RobC »
thanks for the ebay link - but don't think that'll fit a 16v unfortunately.
citronut: good tip. I've always thought the original thing on top of the tank is sited/designed is a perfect way to get smashed by the bonnet every time it's closed...
1991 Citroen BX 16v
easier still, with the T piece, bin it off, drill 2 holes in the lid and stuff the pipes straight into the lid. Thats what I do these days!
docchevron wrote:easier still, with the T piece, bin it off
That's what I've done too but in my case I've used a short piece of fuel hose to link the leak-off plastic hose directly into the centre of the cap. I haven't connected the second plastic pipe because its just a breather that ends open-ended in the wing. I figured that I didn't need the breather because the reservoir cap is not a tight fit so it can breath around the edges.
RobC
x 30
Post by RobC »
Update: sadly Citroen Whitechapel have told me the 16v dipstick and oil temperature sender unit are no longer available (unless anyone else knows any different?)
The LHM tank T/Y piece is though, and duly ordered.
1991 Citroen BX 16v
Try a 205 breaker/specialist - the oil temperature sender is shared. I've also taken one from a ZX before, but I can't remember what model.
Any ZX Volcane has the same temp sender, and is available off he shelf at your friendly local main stealer for £5!
I got my ZX sender for considerably less than that, thanks Chris! :wink:
