hi - i'm having difficulty getting the right part no for the bottom rad. hose on my 1991 TZD... Looking at the Citroen service site - the part no should be:
95638588
according to AEP though this is for a 92 onwards...
Main dealer in Bristol doesn't recognise that part number at all and thinks it should be 95640596 which has the side pipe on and is for the N/A diesel I'm sure...
Anyone have the right number or even a spare hose they could sell me?
thanks
correct 91 TD bottom rad hose..
themildbunch
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
did you enter the last 8 digits of your chassi/VIN No. on service citroen,
if you did that should give you the corect pipe/part No. for your car,
themildbunch
Hi
Yes, I've tried that and that's what the Main Dealer did over the phone...
The Characteristics seems to give me the correct car - BX, 5 door estate, turbo diesel, XUD7TE...
When I go back to the Mechanical > Engine > Cooling section some of the car models have gone and for Water Piping I only see The 1.8 / 1.9 N/A diesels / no Turbo models....
If I don't specify my VIN I can see these
not sure what's going on here...
1988 BX 19 Gti 16v
rmattila
For some reason the turbo diesel model water pipings (as well as the petrol ones) seem to be listed under label "water piping - regulator" rather than "water piping".themildbunch wrote:When I go back to the Mechanical > Engine > Cooling section some of the car models have gone and for Water Piping I only see The 1.8 / 1.9 N/A diesels / no Turbo models..
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
themildbunch
Hi - Thanks but it's odd I still don't get a Turbo Diesel option with my VIN...
I can see the Water Piping Regulator until RP 05637 if I don't specify my VIN which I'm pretty sure is the correct parts page...
Bottom Hose - 95 638 588
Oil Cooler Hoses - 96 015 636 and 1307 J5
Water Outlet Hose - 96 020 099
These all look like they could do with being changed...
I think AEP must have got their parts numbers / dates wrong for this part..
1988 BX 19 Gti 16v
