LHM Change
LHM Change
I did a quick and easy change last week and noticed a huge improvement ie suspension more responsive, steering much lighter. However after reading the relevant section in BX DIY i noted this method should be done in HIGH, i did mine in LOW. Doesn't seem to have caused any problems so far. Am i in for a nasty surprise
I think you must have mis-read or understood it, the only way to get the majority of the lhm bank into the lhm tank is by having it in low & releasing the remaining pressure with the adjustor screw nr to the accy sphere. Its well worth bleeding the brakes, just be very careful with the bleed screws, as they might be corroded in, quite a lot of crap can come out, just keep pressing the brake pedal until it becomes clear, then nip them up.
