The Moment You've All Been Waiting For!
NTShawofLouth
Post by NTShawofLouth »
  • Citroen BX
    Suspension & Steering
    Qty Description Application Part Number
    1 Wishbone Spindle 95611436
    2 Front wishbone front bush 95637690
    2 Front wishbone rear bush 96070064
    1 NSF hub carrier/swivel ABS 95615973
    2 Rear hub & bearing Non - ABS 370142
    1 NSR suspension arm Non - ABS 95571695
    1 Front anti-roll bar 1.6 petrol, 1.7D, 1.9D 95637694
    1 Steering flexible coupling Non-PAS 95631286
    1 Inner steering joint lock washer 405825
    1 Road wheel 5x14, non-vented 95496583
    1 Road wheel 5x14, vented 540163
    1 Road wheel 5.5x14, vented (fits Xantia also) 96155310
    Hydraulics
    1 Cylinder stop plate 527207
    4 Pushrod retaining clip 527209
    4 Stop plate retaining clip 527210
    1 Rear suspension pushrod 95568737
    1 Steering pinion valve PAS 4048G2
    2 Security valve 96151895
    1 Flow divider PAS 402401
    1 LHM reservoir 5491085
    1 LHM reservoir level sensor 527108
    1 LHM reservoir cap 95488446
    1 LHM reservoir filter 5508681
    2 LHM reservoir filter 527106
    1 LHM reservoir retainer 5461317
    2 Front sphere 1.4 petrol 95564253
    2 Front sphere 1.7TD saloon, 4x4; GTi >3877 95630610
    4 Front sphere 1.7TD estate; GTi RP 3878> 96024568
    2 Rear sphere Estate RP 3878>, except 1.7TD 96024566
    6 Front strut return pipe 95622818
    7 Strut return pipe clip 96127591
    3 Hydraulic pump belt Early 1.4 petrol 520006
    3 Hydraulic pump belt Diesel except 6+2; 16V >4223 91536298
    1 Main reservoir return hose Early 1.4 petrol 95567454
    1 Supply hose, reservoir to pump Petrol & PAS, except 16V 95624231
    2 Pipe to brake valve RHD 96093539
    2 Pipe to brake valve RHD 96093540
    2 Pipe to brake valve RHD 96093541
    2 Pipe to brake valve RHD 96093542
    2 LHF brake pipe Non-ABS 95596539
    2 RHF brake pipe Non-ABS 95596540
    2 Front to rear brake pipe Non-ABS 96093534
    2 Front to rear suspension pipe 96119932
    1 Brake pipe to security valve 96093536
    1 Pipe to front brake “T” connector 96093538
    1 Pipe, flow divider to strg pinion Including 1.7TD 96033164
    1 Pipe set, pinion valve to PAS ram PAS, except 4x4 40207A
    1 Pipe, regulator to pump Early 1.4 petrol 95592923
    1 Pipe, regulator to pump Late 1.4 petrol 96028927
    1 Pipe, regulator to pump 1.6 petrol, non-PAS 96020901
    1 Pipe, regulator to security valve Except 1.4 petrol 95605517
    1 Pipe, regulator to security valve Auto, non-PAS 95597151
    2 Pipe, security valve to front h/c 95567431
    2 Pipe, security valve to rear h/c 95595683
    2 Pipe, rear h/c to 3-way union 95595685
    2 RHF suspension pipe 96117586
    1 Pipe, “T” to LHF suspension pipe 95567435
    1 Pipe, pump to flow divider Diesel & PAS 95596564
    2 Pipe, pump to flow divider 1.6 petrol >RP 4101, 1.9 petrol except 16V 95603177
    1 Pipe, regulator to flow divider PAS, except 16V 95596576
    1 Pipe, regulator to security valve PAS 95596578
    1 Pipe, regulator to security valve Auto 95597151
    Brakes
    1 Rear brake caliper 95651079
    1 Front brake disc kit Non-vented 95661746
    1 Rear brake disc kit 95661849
    Gearbox, clutch & transmission
    38 Clutch/brake pedal return spring RHD 95591608
    2 Clutch cable Early 1.4 petrol 95612702
    1 Clutch cable 1.6 & 1.9 petrol, 1.7 & 1.9D 96081712
    1 Clutch cable 16V & 1.7TD 96081710
    2 Clutch kit 1.6 & 1.9 petrol, except 16V & 4x4 2050W2
    1 Clutch relay lever Except 16V & TD 96134964
    9 Clutch relay lever pushrod Except 16V & TD 95567189
    3 Clutch relay lever adjuster screw Except 16V & TD 211810
    1 Clutch cover 16V, 1.7TD, 4x4 petrol 2004A1
    1 Clutch kit Diesel except 1.7TD 2050W6
    1 Long gear rod, from lever (lower) Early 1.4 petrol 95495340
    1 Short gear rod (transverse) Late 1.4 petrol 96006362
    1 Long gear rod (transverse) Late 1.4 petrol 95636577
    1 Long gear rod, from lever (upper) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 95635511
    1 Short gear rod (transverse) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 95495557
    1 Long gear rod (transverse) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 96049753
    1 Transfer casing gasket, small Early 1.4 petrol 210946
    1 Input shaft guide bush & seal Early 1.4 petrol 210912
    1 Splined drive tube Early 1.4 petrol 230214
    1 Clutch fork Early 1.4 petrol 211736
    6 Clutch fork pushrod Early 1.4 petrol 212037
    2 Outer driveshaft gaiter Various 329351
    1 Inner driveshaft gaiter Various 328774
    4 Outer driveshaft gaiter Various 329383
    Engine & Fuel system
    1 Choke cable 95619435
    1 Fuel tank pick-up & return unit Petrol 95610428
    1 Fuel tank pick-up & return unit Diesel 95610427
    1 Metal fuel supply pipe Except petrol injection 95594177
    1 Metal fuel return pipe 95594178
    3 Exhaust valve 1.6 petrol RP 4158>, 1.9 carb 94957
    2 Inlet valve 1.6 petrol RP 4158>, 1.9 carb 94887
    2 Main bearing thrust washer 2.40 Early 1.4 petrol 118 E5
    3 Main bearing thrust washer 2.55 Early 1.4 petrol 118 E9
    2 Main bearing thrust washer 2.60 Early 1.4 petrol 118F0
    1 Cylinder head gasket, std 1.20 Early 1.4 petrol 209A6
    1 Cylinder head gasket, rep 1.40 Early 1.4 petrol 209A7
    1 Rocker cover gasket Early 1.4 petrol 24939
    1 Oil breather pipe Early 1.4 petrol 95588076
    1 Rocker cover gasket 16V 24974
    1 Air intake pipe, to filter casing? 1.7TD 95639404
    1 Air filter casing bracket Various models, petrol & diesel 96059366
    1 Air hose, filter to throttle housing Petrol 1.9 injection, except 16V 96087419
    1 Air intake hose to filter Petrol 1.6 &1.9 injection, except 16V, 1.9D RP 3796> 96015959
    1 Alternator 1.6 & 1.9 petrol; 1.9D >RP 4921 570525
    1 Alternator Late 1.4 petrol, 5/88>9/91 5705JN
    1 Alternator Late 1.4 petrol, 9/91> 5705JS
    1 Starter motor Early 1.4 petrol 580245
    1 Aux belt tension roller Early 1.4 petrol 95495358
    4 Front exhaust pipe Early 1.4 petrol 95588568
    2 Exhaust down pipe Late 1.4 petrol 96012198
    1 Front exhaust pipe 1.6 & 1.9 carburettor 96076275
    1 Transverse silencer Flange fittings (e.g. TD, GTi) 95634351
    1 Rear silencer Estate, 1.7TD & injection 96048419
    7 Oil filter Early 1.4 petrol 95638829
    1 Oil breather/filler neck 1.6 & 1.9 petrol, 16V 117824
    2 RH engine mounting Late 1.4 petrol 184472
    1 Lower rear engine mount, cast Late 1.4 petrol 1807P0
    1 Water pump Early 1.4 petrol 120169
    1 Radiator fan cowling Except 16V & 1.7TD 95593786
    1 Radiator fan shroud Petrol except 16V 95634724
    3 Upper radiator panel Diesel 95633842
    2 Radiator fan shroud Diesel except 1.7TD 95601742
    1 Lower radiator panel 1.7TD 95639271
    1 Radiator fan panel Petrol & diesel, GATE 95593786
    1 Radiator fan panel Petrol & diesel, AOP 95601821
    4 Lower fan panel bracket 2 fan system (e.g. 1.7TD, 16V) 95591751
    1 Top radiator hose Early 1.4 petrol 95566628
    1 Metal coolant pipe, back of head 1.6 & 1.9 petrol, except 16V 95610901
    1 Top radiator hose 1.9D, 6+2 pump? (remote filter) 96170006
    2 Hose, exchanger to thermostat 1.9D manual (remote fuel filter) 1307J5
    1 Hose, to metal pipe back of head 1.9D (remote fuel filter) 1307W2
    1 Fuel filter head, Roto Diesel Diesel (remote fuel filter) 190413
    1 Distributor cap & rotor, Ducellier Early 1.4 petrol, 1.6 petrol etc 594029
    2 Distributor cap & rotor, Ducellier Early 1.4 petrol, 1.6 petrol etc 594031
    1 Distributor cap & rotor, Bosch Late 1.4 petrol 594047
    2 Ignition module Petrol, inc 16V 594548
    1 Ignition lead set Early 1.4 petrol 97533275
    1 Ignition lead set Late 1.4 petrol 5967N9
    2 Ignition coil Late 1.4 petrol, etc 597043
    2 Ignition lead set Early 1.6 petrol 95636601
    1 Ignition lead set Late 1.6 petrol 95659598
    1 Air filter foam Early 1.4 petrol 9401445798
    8 Diesel fuel filter, Roto Diesel Remote fuel filter 9401906148
    8 Diesel fuel filter, Purflux Remote fuel filter 95608910
    17 NGK spark plug Early 1.4 petrol, 1.6 & 1.9 petrol > 7/87 CITBP6EFS
    38 NGK spark plug Late 1.4 petrol, 1.6 & 1.9 petrol 8/87> except cat & GTi CITBCP6ES
    11 NGK spark plug 1.6 & 1.9 petrol with cat except GTi CITBCPR6ES
    4 NGK spark plug GTi 8V except cat CITBCP7ES
    12 NGK spark plug GTi 8V & 16V with cat CITBCPR7ES
    Body Mechanisms
    2 RH external door handle 95562445
    1 LH external door handle 95562446
    1 LHF door lock mechanism For central locking 95573650
    1 Tailgate catch Saloon without central locking 95564093
    1 Tailgate striker Estate 95610886
    1 Bonnet safety hook 95612096
    1 Bonnet striker pin Plastic bonnet 95608415
    1 LHF electric window mechanism CIM 95649395
    1 LHR electric window mechanism CIM 95649397
    Body Electrical
    1 Front wiper motor, Marchal 95494828
    1 Front wiper mechanism, Bosch 95623205
    3 Front wiper arm 95589142
    1 Front screen washer bottle 95633058
    1 Rear screen washer bottle 95633057
    1 Wiper stalk 97533660
    1 Dashboard fuel gauge, Veglia Except GTi 95618753
    1 Digital clock 6155J9
    1 Ignition/door lock set Cross cut key 96070197
    1 Rear wash/wipe switch Saloon 96008430TR
    1 Hazard flasher switch 6239G4
    1 Front foglamp switch 97523100
    1 Heated rear screen switch 95634839TR
    1 Battery positive cable 1.6 petrol & 1.9 GTi 96085588
    1 Battery positive cable 19TRS; diesel RP 4983> 96091774
    1 Battery positive cable Late 1.4 petrol 96030080
    1 Battery negative cable 19TRS, 1.4 petrol 95584782
    Body Structure
    1 LHR wing Mk2 saloon 95612062
    1 RHR wing Mk2 saloon 95612063
    2 Fuel filler flap 95568456
    1 Front subframe Early 1.4 petrol 95631758
    2 LHF wing Mk1 95563211
    2 RHF wing Mk1 95563210
    2 Rear panel assembly Saloon 95587856
    1 Rear subframe Except 4x4 95633140
    2 Front bulkhead cowl top 95563310
    2 Front bumper side bracket 95631043
    4 LHF inner wing side panel 95615414
    1 LHR lamp panel Saloon 95587858
    1 RHR inner wheel arch assembly Saloon 95617022
    1 LHR upper inner wheel arch Saloon 95587860
    1 Rear crossmember Estate 95616854
    1 LHR towing eye Estate 95616852
    1 RHR towing eye Estate 95616853
    3 Lower front crossmember 95615179
    2 Locking plate, front panel 95616626
    Body trims & mouldings
    1 LHR wheelarch protector Estate 95619577
    1 LHR wheelarch protector Saloon 95619579
    2 Rear wing upright seam trim Saloon 95604802
    1 Wheel trim Mk1 RS, etc 95595330
    1 RHF door capping, grey 95632315TL
    1 Rear bumper/tailgate moulding Estate 95619108
    2 Tailgate moulding insert Estate 95619724
    5 Bonnet chevron, chrome 95582304
    3 Wing/bonnet rear edge seal block 95589346
    1 LHR arch moulding 16V, late Phase 1 & Phase 2 95624914
    1 RHF wing moulding, 27mm 95612059XX
    1 RHF wing moulding, 27mm Stainless insert 95633444
    1 LHF wing moulding, 27mm Stainless insert 95633445
    2 LHR wing moulding, 27mm Stainless insert, saloon 95633443
    1 LHR wing moulding, 27mm Saloon 95612064XX
    1 RHR wing moulding, 27mm Estate 95632337XX
    3 RHR door moulding, 27mm 95612072XX
    1 LHF door moulding, 27mm Stainless insert 95633439
    1 RHF door moulding, 27mm Stainless insert 95633438
    1 LHF wing moulding, 27mm 95612058YB
    1 LHR wing moulding, 27mm Saloon 95612064YB
    1 RHR wing moulding, 27mm Saloon 95612065YB
    1 RHR wing moulding, 27mm Estate 95632337YB
    1 LHF door moulding, 27mm 95612069YB
    1 RHF door moulding, 27mm 95612070YB
    1 RHR door moulding, 27mm 95612072YB
    1 LHF door moulding, 52mm 96044541YB
    1 RHR wing anti-chip tape Mk1? 95585105
    1 Badge, 19TXD Later version CIT8511
    1 RHF plastic arch liner 95612078
    1 Rear door aperture seal 95561259
    1 LHF door moulding Mk1 95568912
    Glazing
    4 Windscreen seal Saloon 95619450
    1 Windscreen Clear 95619451
    1 Windscreen Green tint 95653182
    1 RHF door glass Clear 95560673
    2 LHF door glass Clear 95560674
    1 LHF door glass Green tint 96050176
    1 LHR door glass Bronze tint 95633344
    1 RHR door glass Green tint 96050178
    1 LHR door glass Green tint 96050179
    1 RHR door ¼ glass Green tint 96050180
    1 Tailgate glass Clear, heated, saloon 95496514
    1 Tailgate glass Clear, heated, estate 95606651
    Miscellaneous
    1 Wheelbrace 96078629
    2 Air extractor vent filter Saloon 95595456
    1 Air extractor vent filter Estate 95597261
    1 LH mirror, manual 95632283
    1 Mirror control knob, manual 95633648
    2 RH mirror control knob, manual 95624967
    3 Mirror handle foam seal 95638372
    1 RH mirror, manual (with handle) Mk1 95495888
    1 LH mirror, manual (with handle) Mk1 95495892
    2 RH mirror glass Mk1, “HOHE” 95616731
    1 LH mirror glass Mk1, “BRITAX” 95614610
    1 Coin box 96090355XX
    1 Rear lamp earth harness Saloon 95576719
    2 Front brake pad wear loom 95637364
    1 Co-axial cable 95561136
    2 Heater control knob, grey 6451Z7
    1 Glovebox lid release button 95631221TR
Sorry the list isn't brilliant but it's the best I can do. Pleas email me for any prices: ntshawparts@btconnect.com
Thanks
Ed Clarke
N T Shaw of Louth
NT Shaw of Louth
e-mail sent re: 1 Badge, 19TXD Later version CIT8511
Phoned Ed. Got 1st dibs on:- clutch cable 16 valve & TD.
washer bottles
digital clock
1x windscreen seal
rear door seal
Didn't want to be too greedy. :lol:
Contact:
Might be interested in a Mk1 LHF wing, but I'll find out for certain tomorrow.
Ian, I reckon you might be needing this as well - a real weak spot on the early estates :
x 150
Erm, please dont think me rude but you may want to have a think about some of the prices of these items, they were considerably cheaper the last time I enquired.
£60 for a Mk1 door mirror and £42 for a set of plug leads for a Mk2 1.6 wont find many takers. :shock:
The last mirror I bought was £10 and the leads about the same price!
I was asked to enquire about a new FDV - and I got the price back at £450 plus VAT. Don't know if this is expensive or not, but makes an FDV fail a pretty compelling reason for someone I know to break an otherwise OK BX. Maybe?
x 150
Philip Chidlow wrote:I was asked to enquire about a new FDV - and I got the price back at £450 plus VAT. Don't know if this is expensive or not, but makes an FDV fail a pretty compelling reason for someone I know to break an otherwise OK BX. Maybe?
It is considering how much you can get a recon one for, plus you can buy a nice complete BX for that money.
Roverman wrote: £42 for a set of plug leads for a Mk2 1.6 wont find many takers. :shock:
Tim, check out Kitch's thread offering 8mm BX silicone leads at a bargain price to members. Looks to be member price of £7 a set with free delivery! :D
x 150
ooh! ta mate, didnt see that.
i enquired about a saloon back panel and green tint screen, £100 and £90 both pluss VAT :shock:
i would think you could get a new screen including fitting for around that or less,
seems to me he is selling this stuff off at book price's,
x 150
citronut wrote:i enquired about a saloon back panel and green tint screen, £100 and £90 both pluss VAT :shock:
Hmm, its good of Ed to list all these items but again I have to agree they are FAR too much money, and will probably be sat for another 10 years or so otherwise. Surely its best to move them and get something for them even if its a few quid here and there.
! ! ! ! ! ! -------- DAMP SQUIB --------- ! ! ! !
Post by RxBX »
NTShawofLouth wrote:
  • Citroën BX
Thanks
Ed Clarke
N T Shaw of Louth
Hi Ed !
I suggest that you should add an EXTRA colum to you LIST (i.e. price) !
Qty Description Application Part Number PRICE :wink:
AFTER READING the other member comment's on the BX parts/price's !
(Don't bother asking me to list the XM part's, that I offered to post up for you on the two XM forums) !
:lol:
Seams little point in enquiring about any of these parts, where they not on ebay once for similar ridiculous prices?
x 150
Having spoken to my mate who works at NT SHaw in sales, we need to cut Ed some slack here as hes new too all this and only a young nipper. So has no idea about prices, leave it a few days and I expect some alterations may occur once his gaffer has taken a look.
