The price I am asking for the pair is £60 including postage (Courier due to weight) to UK-MAINLAND only, other area's outside the UK mainland @ cost !
If you want to collect them (From Derby near ASDA Spondon) the price is £50 , please note the price is JUST for the struts ONLY !
However they do come with the gaiters, the rubber return pipes (but look like they need replacing) also the strut top mounts (The rubber has started to perish slightly) and the three stud-bolts on the strut top plate mount which hold them into the chassis sheared off when I removed them from the vehicle, but I have ground the spot welded stud-bolt off so as the three holes are there to take some grade 8.8 bolts/grade 8 nuts which will suffice the same as if they were the normal stud-bolts or just use your own strut top mounts !
Please note !
This pair is my LAST available pair and therefore if you are interested in them the first PM which I have the confidence in where a cash payment/pick up or Pay-pal payment can be made to secure them will have them Couriered to you within two to three working day's after payment !
All the best to who-ever secures them !
