Anyone got a front carpet as mine is soaked in LHM.
Not sure how it happened as I have only just discovered that the carpet is soaked and there are deffo no leaks into the car, although the doseur return hose was leaking a lot a few years back.
Its the one that stretches from one footwell to the other.
Carpet, Black, Front, wanted
- x 116
- BXpat
That's quite a strange incident. Are you sure it isn't the heater matrix quietly weeping away? It can leak unseen down the back of the dash.
Another problem is that any 'oily' deposit into the carpet will soak into the insulation which then provides a sponge which is almost impossible to dry out again.
I'm really racking my brain thinking how LHM could get in there because even if the doseur return was leaking, how would it travel through the bulkhead?
sdelasal
Leobx16v
i have a carpet in good condition also have more items if needed i have made a thread under 16v interior...
1991 Citroen BX 16v - Red
1991 Citroen BX 16v - Silver
1992 Citroen BX 16v - White
Scrapped:
G650PGX 1989 ph.2 red BX 16v
G-VOT 1989 ph.1 White BX 16v
Scrapped:
